R56 2007 mini s issue (p1638)
I have a 2007 mini cooper s with the 1.6l turbo I recently replaced the clutch and antifreeze of course. I was driving it great until I pushed it harder. Around 3-6500 it loses all hp and almost like it dies and comes back to life pulled a hard code (P1638) what do you think it is? And where is the throttle body at?
Jacob--
Here is a link to code p1638-
http://mechanics.stackexchange.com/q...per-p1638-code
Motor Vehicle Maintenance & Repair beta
Questions
Tags
Users
Badges
Unanswered
Ask Question
Take the 2-minute tour × Motor Vehicle Maintenance & Repair Stack Exchange is a question and answer site for mechanics and DIY enthusiast owners of cars, trucks, and motorcycles. It's 100% free, no registration required.
Mini Cooper P1638 code
up vote
down vote
favorite
I have a 2007 Mini Cooper. It keeps throwing code P1638 on my code reader on these really really cold mornings, and the engine seems to search for idle, reving betwween 500RPM and 1400RPM. The car runs fine after it warms up, I clear the code and restart the engine.
What is wrong, and what should I do to fix this permanently?
engine obd-ii idle
shareimprove this question
edited Feb 13 '14 at 21:10
Paulster2
22.4k21650
asked Feb 13 '14 at 20:11
Bob
1516
add a comment
activeoldestvotes
up vote
down vote
I'd try squirting some WD40 into the throttle body assembly first, before considering replacing it.
As Paulster2 said, sometimes the body gets gummed up or, in your case, stuck from cold - WD40 will help lubricate the body and save you some money.
I've used this trick a fair bit, and usually do it once during my own mini service of oil and filter change - so every 6ish months, and never had a problem.
shareimprove this answer
edited Feb 14 '14 at 11:45
answered Feb 14 '14 at 11:00
Nick
723315
+1 Old school FTW! – Juann Strauss Feb 14 '14 at 11:29
I can't believe I didn't mention this, but I have the S model. Is the throttle body a nightmare to get to if you have the S model? I have been assuming it would be, but haven't actually looked (been too cold in the North East to do anything outside). Also, isn't it odd that the engine can be revved while it's throwing a "stuck" code? What's with that? It only goes away after the engine is warm; restarting before warm you'll still have the idle searching problem. – Bob Feb 14 '14 at 17:24
Well, it's just gummed up from cold and maybe dirt. The WD40 trick along with cleaning will help. If you notice that the issue is happening every week or month, replace the throttle body (keep the old one, it's probably still good!) – Nick Feb 14 '14 at 18:53
add a comment
up vote
down vote
P1638's code is: Throttle Valve Position Control; Throttle Stuck Temporarily ... since I don't know a lot about the Mini Cooper, generally I'd say the motor for your throttle position control is sticking due to freezing or age (gummed up). This should be a user replaceable item (mechanic not needed unless you are a complete mechanical nightmare), just ensure you are getting the correct one for your application. It appears each different engine type uses a different type (or at least a different part number) for the throttle body. Partsgeek.com has them.
answered Feb 13 '14 at 21:38
Paulster2
22.4k21650
Questions
Tags
Users
Badges
Unanswered
Ask Question
up vote
down vote
favorite
engine obd-ii idle
Paulster2
22.4k21650
Bob
1516
add a comment
activeoldestvotes
up vote
down vote
Nick
723315
add a comment
up vote
down vote
Paulster2
22.4k21650
09R56
Nov 16, 2022 10:49 AM
SosoMINI
Nov 22, 2015 03:17 PM
fm.illuminatus
Aug 10, 2015 12:15 AM
jrezzo
Aug 9, 2015 10:32 PM
calebmil
Aug 7, 2015 05:54 AM
