OBDII scanner worth it?
Old May 8, 2015 | 08:14 PM
Catch_Me's Avatar
Catch_Me
Hey, I was just wondering, Ive been kinda looking into OBDII scanners after I started working on the mini both as just a kinda fun thing with gauges to play with as well as a tool to read codes and other things. I was wondering what is the best one for use with a iPhone 6 and what is the best app to use with it to get the least hassle and the best use out of the tool. Thanks
Old May 9, 2015 | 07:18 AM
Ta87's Avatar
Ta87
Folks have said very good things about Torque. It's like $5 I think but if I'm not mistaken, you'll need some sort of connector. I think if you got a Bluetooth adapter for your OBDII and paired it to your phone, you could do away with cables.
I use a ScanGauge II that connects via wire.
Old May 12, 2015 | 03:42 AM
pav5069's Avatar
pav5069
You can buy a scanner from Amazon for 5-10 bucks. Worth every penny
Old May 29, 2015 | 10:18 AM
Fizzyx's Avatar
Fizzyx
+1
One of the inexpensive bluetooth OBDII adapters and Torque for your smart phone.
Old May 30, 2015 | 05:48 PM
jamez's Avatar
jamez
The Torque app is unavailable for iOS.
Not all Bluetooth dongles will work with iOS.
I use the more expensive (but guaranteed ios compatible) GoPoint Bluetooth dongle (and have been using it since my iphone4). The dash command app is also expensive, but I use it on my iPhone 4, 6 and iPad 2. I also now have a pioneer 7" head unit that has the capability to use dash command from the hard wired iPhone 4 (still have yet to install it). With the gauges displayed, it should really be awesome.
Old May 31, 2015 | 06:09 AM
05r50's Avatar
05r50
This is true. Apple is very picky about what they allow and OBDII info over Bluetooth is not a thing they like.
However, there is a wifi dongle that will work with apple. It is more costly and they apps are also more costly.
In my opinion it is cheaper to get a used android phone or tablet on eBay and then a BT dongle and Torque App. Overall cost would be pretty cheap.
For realtime monitoring I prefer to use a ScanGauge II in my MINI. It plugs into the OBDII port and can provide view of 4 "gauges" at one time and you can select the ones you like. Can buy online or auto zone. It also reads and clears codes.
Finhead
Electrical
Apr 12, 2019 04:05 PM
RobbyD
Jan 29, 2019 01:22 PM
navybsn
Oct 5, 2018 04:42 PM
mauiguyharry
Oct 8, 2015 06:53 PM
GAT
Oct 4, 2015 07:27 PM
