R56 Black Jack on Black Roof Sun Roof?
The Decal offered by Mini states that it is for white roofs; why so? Seems like it would look nice on a Black roof and particularly with the matching mirror covers. Any one understand why the item states that it is for white roofs? This goes on a tinted sun roof anyway.
It's because the decal is not solid - it relies on the color of the roof to "fill in" the areas that are meant to be white in the graphic. Even if you might like the look of the graphic over a black background instead of white, MINI can't rightly sell a product with an advertised end result unless they clarify beforehand what's required to make it turn out that way. But unless you have a flat black roof, you likely won't see the blackjack design very well since one of the two colors of the roof graphic is already gloss black.
As far as sunroofs go - MINI says their full roof graphics can't go on cars with sunroofs but this is not true. The decal just needs to be trimmed in the proper places to allow the sunroof to function properly. MINI probably got too many people complaining about how the roof graphics obscure the view out of the sunroof glass, so they made special "sunroof only" graphics that are printed on a mesh-like vinyl to allow a somewhat unobstructed view through the glass.
These comments were on the sun roof graphics decal part no. 51140418665. Does Mini make a white sunroof? All I've seen have been black. Thanks for the replies so far. I'm still confused. I'm guessing it was due to using boiler plate material for the description.
I've never heard of MINI specifying roof colors for their sunroof-only decals. It really doesn't matter if they do anyway, since the sunroof graphics are dealer installed accessories and the dealer will pretty much put anything you want on your car at purchase - they make a fortune off that stuff. As far as I know, none of the sunroof-only graphics rely on the roof color to show through, but I could be wrong. If they did though, you can be sure it is black that they require. For mine, having a black roof with sunroof was essentially the same as having a solid black roof, so I just had to make some extra cuts to any of the white squares that covered the sunroof gaps.
Previously I had a white roof MINI with a sunroof, so when I installed checkers, I had to use white squares over the sunroof and black for the rest. With creativity, having a sunroof on either a black or white roof really doesn't matter. It's only when using the MINI configurator that you'll run into incompatibilities.
Is there such a thing as a white Sun/Moon roof? If so then the white only disclaimer could be correct. If no then it is a Mini typo.
gmonde
Sep 8, 2015 06:37 AM
