R52 Windows don't go down using toggles switch but will from upper central console
Old Apr 30, 2015 | 11:36 AM
Enthdegree's Avatar
Enthdegree
I have a weird problem; my front windows will not go down when using the toggle switches but when I use the wind shield centre console switch all 4 windows go down like normal. At this point I can use the toggle switch to bring the windows back up but they will still not go down. Is this just a programming problem?
Old Apr 30, 2015 | 12:40 PM
Mib4840's Avatar
Mib4840
Try resetting your ECU. My R53 would do something similar and the reset would fix it. You may have to do it a couple times though.
Old Apr 30, 2015 | 01:39 PM
Check that the toggle switch is plugged in all the way on the back.
The over head switch control those rear windows. The front toggle are only for the front windows.
Old May 1, 2015 | 05:01 PM
Enthdegree's Avatar
Enthdegree
I reset the ECU and now the drivers side is working, I plan on trying again tomorrow to see if I can get the passenger side to work.
Old May 4, 2015 | 05:46 AM
thanks for the update. Let us know how it goes.
Cereall
Sep 5, 2019 06:05 PM
surfblue
Oct 24, 2018 01:20 AM
theblackfalcon
Oct 11, 2015 09:49 AM
Alkaidovich
Aug 10, 2015 08:20 AM
