R56 Low Speed Fan and Heater
Old Apr 29, 2015 | 12:23 PM
solankill's Avatar
solankill
Hello everyone, my first post here on NAM.
I am having issues and wonder if anyone can help out. I searched the forums and cannot seem to find a good fix to this problem in the r56.
I have a 2009 Cooper Justa. Here are the issues,
Leaky Thermostat Housing Fixed
Leaky Water pump Fixed
Low Speed Fan not working
For some reason, the fan does not turn on until the car gets to about 115 C or until I turn on my AC and keep it on. It should be around 80 C with the low fan but it never comes on.
Heater works intermittently
When I use the heater, it runs hot like it is supposed to but then it will blow cold air and then it will blow hot air again and so on.. I have absolutely no idea why this does this.
This is my first mini I bought used some 25K miles ago and am worried that this may have been an impulse purchase.
Please help!!
Old Apr 29, 2015 | 01:28 PM
holkki's Avatar
holkki
Possible air in cooling system,"air pockets" that interfere with the coolant circulation.
Old Apr 29, 2015 | 02:12 PM
solankill's Avatar
solankill
Would that cause both issues?
To bleed the system would I just run the engine for a while with the coolant cap off? Or is there a better way to do this.
Old May 11, 2015 | 12:29 AM
holkki's Avatar
holkki
Yep,there is bleeding screw on thermostat housing,be care! It is "plastic" screw,just open a little when the engine is hot, idle runnning.Then add, if necessary, the coolant fluid when the engine has cooled slightly.
Old May 11, 2015 | 10:03 AM
solankill's Avatar
solankill
Thanks Holkki, unfortunately this did not fix the issue, any other ideas? Would the coolant fan Low speedy be one of those resistor issues?
Old May 11, 2015 | 12:07 PM
holkki's Avatar
holkki
Maybe..I remember reading that a number of factors affecting the operation of the fan , like AC , speed/loading, torque, sport button etc.
Old May 11, 2015 | 11:20 PM
solankill's Avatar
solankill
Okay, I may just replace the radiator, I think that should fix the issue.
Old May 12, 2015 | 02:21 AM
holkki's Avatar
holkki
Have you considered the first cooling system flushing?It`s a cheaper way and do not mind even if you change a radiator..When I flush my car cooling system, I remember how tricky was bleeding the system, it helped when squeezing the lower and upper water hoses.
Old May 12, 2015 | 09:36 AM
solankill's Avatar
solankill
I can do that first, I will give it a go in the next few days and see the results. Thank you for your help, I will keep you updated.
Old Jun 29, 2015 | 04:49 PM
solankill's Avatar
solankill
So the thermostat ended up leaking again. I changed it out and bled the system and the heater works again. I am still having issues with the cooling fan though. The 1st stage or low speed is not coming on. I cannot find anything on the forum for a r56. Any suggestions?
silence2-38554
Nov 12, 2015 09:39 AM
theblackfalcon
Oct 11, 2015 09:49 AM
danielbrookes_9
Oct 3, 2015 12:51 PM
David.R53
Sep 1, 2015 06:51 PM
