Navigation & Audio Gen 3 audio specs.
Old Apr 27, 2015 | 10:23 AM
BazV's Avatar
BazV
Gen 3 audio specs.
Does anyone have the specs for the audio in the gen 3 minis?
I'm thinking about changing my 2012 clubman to a gen 3 Cooper SD but have a concern regarding the front door speakers.
By the looks of it, mini have got rid of the lower door speaker? Is this across the range?
Has anyone upgraded the audio in a gen 3?
What size are the speakers?
Old Apr 27, 2015 | 12:49 PM
bavmotors's Avatar
bavmotors
Have you heard the stereo in the gen 3? Honestly you would be better off going aftermarket, the new sound systems, even the HK are seriously lacking imo.
Old May 10, 2015 | 02:43 AM
tommydh's Avatar
tommydh
Do yourself the favor and go aftermarket. Theres a lot of options out there. If you need any help with anything on it hit me up the shop I used to work at did a couple clubbies and I did a few builds on my 07. The 3rd gen speakers are all a 4" component set in the H/K at least.
Old Sep 10, 2015 | 03:17 PM
BazV's Avatar
BazV
Oh im definately going after market equipment, of which I have a lot of already in my 2012 Clubman, but next week I pick up a F56 Cooper SD, so was inquiring about its standard setup etc
I have in my Clubman at the moment the following:
Audison Bit One
Audison Bit Play HD
Hybrid Audio L6v2
Hybrid Audio L1 Pro
Alpine F6 amp
Alpine M12 amp
Diamond Audio TDX12
So play to install most of the equipment into the F56
Old Sep 10, 2015 | 03:46 PM
F55MidnightBlackCooperS's Avatar
Audison Bit One
Audison Bit Play HD
Hybrid Audio L6v2
Hybrid Audio L1 Pro
Alpine F6 amp
Alpine M12 amp
Diamond Audio TDX12
4x 4 inch and 2x 6.5 subs under the seats on the base cooper s stereo.
Keep the audison and alpine stuff, get a set or morel 4 inch components,2 4 inch morel mid woofers and a 10 inch morel shallow mount sub.Focal,rainbow and gladen make underseat 8 inch subs for bmw fxx series cars that the mini is based on.
Had those amps in my r56! Ran focals then morels in the r56. The morel drivers and the Alpine amps are made for each other.
Old Sep 10, 2015 | 03:55 PM
BazV's Avatar
BazV
Originally Posted by F55MidnightBlackCooperS
4x 4 inch and 2 6.5 subs under the seats on the base cooper s stereo.
I would most likely buy a set of 4" Hybrid Audio mids or something for the front and look at the floor speakers positioning/depth/specs etc and consider what to replace it with. Ill see if I can hold of some spare floor speakers too.
Old Sep 25, 2015 | 10:49 AM
GregoryK's Avatar
GregoryK
Having gutted my F56. There is not much room to install stuff behind the panels. Also the HK system use Canbus. This means you have to plug the HK amp in when you go for service or they can't upgrade the software.
Old Oct 11, 2015 | 05:14 PM
BazV's Avatar
BazV
CANBUS? You mean MOST??
My F56 does not have an amp, it does have the media XL and so on package. No HK or amps. Has 4" speakers in the doors and im guessing 6.5" woofers under the seats.
Does anyone know if my set up uses optical connection? Or has it even without an amp? I tried earlier to take a look behind the media screen for a optical cable but wasnt successful in fully taking the screen secion out to see the connections at the back of it.
Old Oct 11, 2015 | 07:05 PM
GregoryK's Avatar
GregoryK
look up Canbus. It's the central nervous system that integrates all the computers and knows if things are working or not.
The Head Unit has 4 line level outputs. Same on base and HK system.
Old Oct 12, 2015 | 12:49 PM
BazV's Avatar
BazV
Does it not also run on a MOST system? I understand with the HK system is connected by optical?
Do you have any pictures of the car when you gutted it?
Old Oct 12, 2015 | 01:00 PM
BazV's Avatar
BazV
Also, are there any wiring diagrams for the stock audio setup?
Old Oct 12, 2015 | 01:30 PM
GregoryK's Avatar
GregoryK
NO optical. Check under defeating asd. Do a search. I've posted diagrams. No Optical. Speaker level in all systems.
Old Oct 14, 2015 | 01:46 AM
BazV's Avatar
BazV
Thanks Gregory, ive read a few of your threads, very informative info there, thanks
Im still looking into the connections side of things to get my audio kit installed into my F56 soon.
So, if (in my set up which does not have HK) I could tap into the speaker connections before the ASD and use that as high level input into the Bit One?
Also do you have any info on how to take the central display unit out?
Old Oct 14, 2015 | 04:32 AM
GregoryK's Avatar
GregoryK
That's what I would do - high level straight into the DSP.
When you say take the central display out - why is this? Get to the wring?
Keep us posted. Greg
Old Oct 14, 2015 | 10:45 AM
BazV's Avatar
BazV
I managed to remove the central display, heater controls section and had a look at the actual head unit thats housed behind the main screen. Lots of connections. I took a bunch of photos so will host them on here in a bit.
Yes I want to see how its wired up, I think there is an optical connector there. Ideally need to see the wiring from a car with HK, and compare.
Old Oct 14, 2015 | 10:48 AM
BazV's Avatar
BazV
This is the head unit that is in my 2015 MINI Cooper.
The pink connector that has nothing connected to it.... hmmmm
Old Oct 14, 2015 | 11:37 AM
GregoryK's Avatar
GregoryK
The Head Unit is the same in both systems. This is a Mini not a BMW. The system is low res. No Optical. You can look ask you want. 4 channels in each system. The HK just amps more and has more, better, speakers. I would patch before the asd. leave it hooked up though.
Old Nov 2, 2015 | 04:41 PM
BazV's Avatar
BazV
Do you have a links to your installs in a gen 3 please?
Old Nov 3, 2015 | 04:21 AM
GregoryK's Avatar
GregoryK
I never did a write-up on my previous install. I have a new car now. Here is a post I made on the ASD unit. I will have some helpful diagrams. I also have full stereo colored coding drawings somewhere but would have to dig. Let me know if this ii enough?
https://www.northamericanmotoring.co...esign-asd.html
Old Nov 3, 2015 | 09:28 AM
BazV's Avatar
BazV
Oh right, what car have you got now?
If you could dig out the full wiring drawings that would be amazing , much appreciated.
Yes I read about the ASD module, i plan to bypass it
Old Nov 3, 2015 | 10:33 AM
GregoryK's Avatar
GregoryK
The problem is the files I have are in a weird format that is hard (impossible) to read if I turn them into jpg's. PM me and I'll email them to you.
I have a 2016 JCW.
Old Nov 3, 2015 | 03:58 PM
BazV's Avatar
BazV
I have a 2016 JCW.
Thanks, ill PM you now.
Any plans for the JCW?
Old Dec 21, 2015 | 05:36 PM
BazV's Avatar
BazV
I have a 2016 JCW.
hi Gregory, I was wondering if you knew which colour coded wires come from the head unit that I can use as an input into my Bit One?
Old Dec 21, 2015 | 07:03 PM
GregoryK's Avatar
GregoryK
Yes I have a wiring diagram. Think I posted it before but here it is for the HK system. But the colors are the same. 4 channels from the HU.
Hope this helps.
Old Dec 22, 2015 | 12:56 AM
BazV's Avatar
BazV
Thanks Gregory, do you know which ones are Left Right Front and Rears? I think im only going to use the front signals but does the head unit send PDC sounds to the rears?
May have to use all four I think.
