R56 outside door handle not working
Old Apr 24, 2015 | 04:41 AM
Todd Gerken's Avatar
Todd Gerken
I'm having trouble with my passenger outside door handle working. I can get it to work once in a while if I fight with it but the inside handle works fine. Any ideas what might need replaced?
Old Apr 24, 2015 | 06:49 AM
Finner's Avatar
Finner
I have the same problem but with the driver door. Except it only happens about once a month to me. When Mini was in for oil service they looked at door, oiled mechanism I think. It worked fine when at dealer so they couldn't find the problem. It hasn't happened again since it was in for service.
Old Apr 24, 2015 | 06:59 AM
Todd Gerken
Thanks. Maybe I will just pull the door apart and lube it well and see if that helps. At this point I just open from the inside because its almost never working.
Old Apr 24, 2015 | 07:42 AM
Mini2na's Avatar
Mini2na
Try this: PUSH the door in while squeezing the handle latch bar. This relieves the pressure on the door latch and can make it much easier to release it. Then you can lubricate the latch mechanism and start opening the door as usual.
Old Apr 24, 2015 | 07:47 AM
Todd Gerken
I will try this after work. Thanks
Old Apr 29, 2015 | 02:14 PM
Todd Gerken
Thanks for the tips. I sprayed it with PB Blaster for 2 days then with PB Blaster lube and an Oil lubricant. Now it is working almost like new. Thank you again.
boostedhaze
Jan 2, 2018 07:26 PM
xpunisherx
Sep 1, 2015 11:47 AM
minimaximum
R55 :: Clubman Talk (2008+)
Aug 14, 2015 04:05 PM
CM2011RG
Aug 5, 2015 02:00 PM
