R50/53 100,000 Mile Club
Old Apr 23, 2015 | 08:56 PM
FatherG's Avatar
FatherG
100,000 Mile Club
'02 r50
Old Apr 24, 2015 | 04:01 AM
JABowders's Avatar
JABowders
Veteran: Army
Yeay! Milestone...
Motpr on!
Old Apr 25, 2015 | 09:55 PM
LoneWolf_R53's Avatar
LoneWolf_R53
Just hit 136,685 today.
Old Apr 26, 2015 | 06:37 PM
pav5069's Avatar
pav5069
I just hit 100086 so I just got there.
Old Apr 27, 2015 | 06:15 PM
IQRaceworks's Avatar
IQRaceworks
I"m around 134,000 the last time I looked
Old Apr 28, 2015 | 10:51 AM
Razor2015's Avatar
Razor2015
Hi,
Just purchased a pretty cheap, April 2006 production Mini Cooper RHD, manual 5-speed, R50 from Japan. I am assuming this is the same as a UK or European spec?
Has 135k KMS (84k miles) on the clock and has a few bumps and bruises as can be seen in the pics attached.
Car is on the way to the Caribbean so I have a few months to make a plan.
Any one here ever changed a rocker panel, easy? Any suggestions on best place to purchase a new one from USA?
I assume that is just a little plastic cap next to the light that is missing, any ideas where to purchase in the USA?
Interior looks pretty clean and in good shape considering the outside of the car.
OK, worst part is the rear dent, even some rust showing. Don't think I will replace the whole quarter panel, probably just cut out the rust, weld in some new metal and then bondo, paint, etc.
Hope the clutch is still good, at least it has the Getrag gear box which hopefully is OK too.
Car isn't coming with any service history so planning on doing the items below. Any other suggestions? Very near to that 100k miles mark, what major items have you had to deal with on the way?
Change oil and oil filter (oil suggestions for a hot Caribbean climate?)
Change air filter
Potential:
Change brake pads and discs
Fuel filter
Plugs and wires
Tires
Thoughts and suggestions welcome. Thank you for your time.
Attached Thumbnails 100,000 Mile Club-bottom.jpg   100,000 Mile Club-dent.jpg   100,000 Mile Club-interior.jpg   100,000 Mile Club-light.jpg
Old Apr 28, 2015 | 12:19 PM
scullersusan's Avatar
scullersusan
Solar Metallic Red 2006 Cooper
Near 150,000. Never a blip or problem. Love my Mini!
Old Apr 28, 2015 | 01:24 PM
JABowders's Avatar
JABowders
Veteran: Army
Rocker plastic is easy to do , you can finish faster than you can drink a Red Strip. Example of the part: http://www.ecstuning.com/Mini-2006-C...irts/ES127383/ $83.69
Headlight Washer Cap: http://www.ecstuning.com/Mini-2006-C...iper/ES172796/ $8.85
Rear Quarter: http://www.ecstuning.com/Mini-2006-C...ender/ES71998/ $284.53
You want to check your lower control arm bushings, make sure your strut towers haven't mushroomed.
Change air filter
Potential:
Fuel filter
Plugs and wires
Tires
Don't forget to change the cabin air filter as well.
Use the recommended Oil you should be fine.
Once you get it up to par it is easy to keep it up... keep it off the beach and don't park off the end of any piers...
Welcome to the MINIacs!
Motor on!
Old Apr 28, 2015 | 01:32 PM
Razor2015's Avatar
Razor2015
Motor on!
LOL, great help! Thank you
Old Apr 28, 2015 | 02:04 PM
Razor2015's Avatar
Razor2015
LOL, thank you!
Old Apr 28, 2015 | 02:19 PM
+1 JABowders bring the A game today.
Old Apr 29, 2015 | 04:14 AM
nydog's Avatar
nydog
'04 R53 purchased nearly 2 weeks ago closing in on 115k miles.
Old Apr 30, 2015 | 07:09 AM
Razor2015's Avatar
Razor2015
Motor on!
Hi,
Was looking in to this mushrooming a little more. Has things like the below been proven to prevent mushrooming from starting or prevent further mushrooming? I actually don't see how a plate below or above would help, wouldn't the sides / tower stretch then if the metal wasn't designed thick or strong enough to handle the small shock travel / abuse?
http://new.minimania.com/part/NMS730...rcement-Plates
Any comprehensive links and real world examples I can be directed to?
Old Apr 30, 2015 | 09:15 AM
Razor2015's Avatar
Razor2015
Motor on!
Hi,
Old Apr 30, 2015 | 10:42 AM
Razor2015's Avatar
Razor2015
Hi,
Does any product truly prevent strut mushrooming or can prevent further mushrooming? Bold claims here:
http://www.madnessmotorworks.com/mad...nt-plates.aspx
Was there ever a conclusion on what the best way forward was to prevent and halt mushrooming?
Old May 1, 2015 | 05:39 AM
Razor2015's Avatar
Razor2015
bttt
Old May 1, 2015 | 06:47 AM
dongood's Avatar
dongood
Hi,
I never understood how bolting something to the top of the strut tower would have any significant impact on stopping forces from the bottom.
There are plates that bolt under the tower, essentially a wide top mount. This does not decrease the forces but spreads them out. May prevent mushrooming but is it setting you up for a more catastrophic failure later? Conventional wisdom says no so far, but you do raise the front by a few millimeters.
Finally you can sandwich the strut tower, using a plate from the bottom and top, perhaps the top having a cross brace for more stiffness?
For me the under tower plates make the most sense.
Old May 1, 2015 | 07:05 AM
Razor2015's Avatar
Razor2015
I agree, would love to hear some real world examples.
Old May 1, 2015 | 03:55 PM
jennster's Avatar
jennster
05 MCS Purple Haze about 100200. Keepin it forever!
Old May 1, 2015 | 08:04 PM
Rich.Wolfson's Avatar
Rich.Wolfson
Artoo, 2003 MCS, passed 150,000 miles this afternoon. For laughs I did a compression test. 155/160/170/165.
I say not bad and not exactly what I expected.
///Rich
Old May 4, 2015 | 09:52 AM
cooperdude's Avatar
cooperdude
I'm a little past 100,000...
I'll be hitting 233,000 this week!
2004 Cooper - First Owner
Attached Thumbnails 100,000 Mile Club-14662_10153286116014459_4968346924440680814_n.jpg
Old May 4, 2015 | 10:00 AM
Razor2015's Avatar
Razor2015
Incredible, any chance of providing a list of service items and any major repairs or replacements?
Old May 6, 2015 | 05:12 AM
Razor2015's Avatar
Razor2015
bttt
Old May 6, 2015 | 10:40 AM
ToroPerro's Avatar
ToroPerro
2006 Cooper
My 06 Cooper is at 143,000 and I plan on keeping him at least one more year...
Old May 6, 2015 | 08:30 PM
The Guarachero's Avatar
The Guarachero
I assume that is just a little plastic cap next to the light that is missing....
Check first to see if the headlight washer isn't broken. I made the mistake of buying the cap, then when i saw that it wasnt snapping into place i checked the washer. I heard that the headlight washers tend to break after wear and tear. You can find the part at ecstuning.com as well. Let me guess! Its the right one? (Passenger side)
