R56 New starter installed - Turning but not engaging?
Old Apr 20, 2015 | 06:20 PM
Plafnd's Avatar
Plafnd
Hi,
Today we changed the starter on my MINI R56 Justa and we we went for the 'start', we heard the big starter going like 'zuuuuuuuuuuuuuuu' but not engaging into the engine.
I know, we already thought about Selenoid not well plugged but the connection are really simple. Just the sqaure plus ang the big red cable on the bolt.
The connections look clean...
Any Help, it is urgent... She's stuck on the ShopRite Parking!!
Old Apr 21, 2015 | 08:43 AM
Plafnd's Avatar
Plafnd
I am pretty sure it comes from the solenoid.
It is not pushing the flywheel. So two solutions :
- or it doesn't receive power (electrical problem) where is the Fuse corresponding, I can't find it!
- or dead solenoid if it received power.
I am gonna try with a voltmeter to check if it receives power which I think it doesn't (only solenoid, the big servo engine of the starter works).
Is anybody can give me the location of the corresponding fuses or relays for the solenoid ?
Thanks a lot guys.
Old Apr 21, 2015 | 09:06 AM
Tio Barry's Avatar
Tio Barry
Are you certain that the engine is not seized? Was the flywheel turning?
Old Apr 21, 2015 | 09:56 AM
Plafnd's Avatar
Plafnd
Yes everything is really fine and doubled inspected. It's the solenoid not pushing the flywheel!
Do you know what relay is the one that is for the solenoid ?
Old Apr 22, 2015 | 08:09 AM
Tio Barry's Avatar
Tio Barry
Looking at the diagram. Electronic Immobilizer Control Unit acts on starter. This unit has input from A/T trans control unit, ignition switch, gear position switch (in and out of park position?).
Old May 1, 2015 | 08:15 PM
Plafnd's Avatar
Plafnd
Small update.
The starter worked fine. It was only not positioned very well because of a spring in one of the bolt was missing from the old starter. The flywheel was not going in.
Old May 2, 2015 | 05:53 AM
Tio Barry's Avatar
Tio Barry
Glad you're up and running.
adrchn
Aug 13, 2019 02:11 AM
squawSkiBum
Oct 2, 2015 09:21 AM
Mini Cooper r56 Pr
Aug 12, 2015 07:42 PM
kpl
Aug 11, 2015 04:52 AM
