R50/53 SOMEONE HELP!!! How to properly bleed all air out of clutch system
Old Apr 18, 2015 | 04:28 PM
Bean0709's Avatar
Bean0709
My husband just installed a whole clutch in my 2006 MCS including a new slave cylinder and he seems to be having a heck if a time getting all of the air out of the system, even with a pressure bleeder. Anyone have an easy way to do this???
Please help as he is getting super frustrated!!
Old Apr 18, 2015 | 07:45 PM
Milpol's Avatar
Milpol
try this
Old Apr 18, 2015 | 08:12 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
There is a special tool to do it. The tool compresses the slave cylinder then you bleed it just like normal. So if you can find a way to compress it you can then bleed it. If you don't you'll never get it bled.
Old Apr 20, 2015 | 02:49 PM
mrchet's Avatar
mrchet
When I did my clutch I used the 2x4 block of wood method.
Place a 2x4 long enough to completely depress the clutch between the pedal and the drivers seat overnight.
I wasn't a believer but sure enough, it worked for me.
Old Apr 20, 2015 | 06:53 PM
Bean0709's Avatar
Bean0709
Originally Posted by mrchet
When I did my clutch I used the 2x4 block of wood method. Place a 2x4 long enough to completely depress the clutch between the pedal and the drivers seat overnight. I wasn't a believer but sure enough, it worked for me.
We will give this a whirl. We managed to get most of the air out, but it seems there may still be some air trapped some place. The gears are not engaging smoothly when car running, but do so when it is not running.
Old Apr 21, 2015 | 05:42 AM
Bean0709's Avatar
Bean0709
Originally Posted by Bean0709
We will give this a whirl. We managed to get most of the air out, but it seems there may still be some air trapped some place. The gears are not engaging smoothly when car running, but do so when it is not running. Sent from my iPhone using NAMotoring
That worked!!!! Thank you so much!!!
Old Mar 18, 2020 | 09:52 AM
booyah93's Avatar
booyah93
Holy crap... I'm not a believer, but I guess I'll do that. I didn't change my slave cylinder as there seems to be nothing wrong, but after replacing the clutch the pedal is very soft and I can't shift with the car on but I can with it off. There is a bonus issue that if I get it in gear the wheels wanna roll.
eliseo1981
Jan 28, 2021 02:45 PM
theblackfalcon
Oct 11, 2015 09:49 AM
durablack
R55 :: Clubman Talk (2008+)
Oct 5, 2015 01:51 PM
Gipper
Aug 8, 2015 05:39 AM
