R50/53 R53 Loud Fan Noise
Old Apr 18, 2015 | 11:52 AM
Newyork167's Avatar
Newyork167
R53 Loud Fan Noise
Hi Everyone!
I'm having a weird fan noise when I engage the A/C. It comes on shortly after the engagement and turns off after the A/C is turned off. I tried to listen to the power steering fan and I'm uncertain of whether or not it's coming from there. It sounds loudest behind the radiator.
Here is a video I found that shows the same noise (starts the noise at around 11 seconds):
I've seen people say that it is the power steering fan (which I am pretty sure it is coming from up higher in the engine bay) or some A/C compressor fan. Hoping someone here could guide me through some of the diagnostics of this problem.
Thanks!
Old Apr 18, 2015 | 02:14 PM
TimL's Avatar
TimL
That does sound to me like the power steering fan. Depending on your driving and ambient temps, this may or may not be an issue.
I ran into a problem with my fan coming on frequently last summer after even just moderate driving, but especially after stop-and-go city driving. It ended up that I had a failed thermostat housing -- a common failing apparently. I had the thermostat replaced and so far the situation seems to be resolved.
Old Apr 19, 2015 | 07:40 PM
derangedoffroad's Avatar
derangedoffroad
Sounds like the high speed operation of your radiator cooling fan. Its possible the low speed resistor has failed, causing only the high speed portion to operate.
Old Apr 19, 2015 | 08:42 PM
Debi's Coop S's Avatar
Debi's Coop S
I agree, it's definitely your radiator cooling fan on high speed. I had the same issue with my fan not working on low speed, but worked on high.
Old Apr 19, 2015 | 10:19 PM
Rrotz's Avatar
Rrotz
I may have this as well.
Engine noise - YouTube
"> Engine noise - YouTube
" type="application/x-shockwave-flash" width="425" height="350">
Old Apr 19, 2015 | 10:20 PM
Rrotz's Avatar
Rrotz
Why does my youtube video show up twice?
Old Apr 21, 2015 | 03:06 PM
Filmy's Avatar
Filmy
It's definitely your high-speed fan circuit kicking in. Here's the link to the low-speed resistor issue, but it's a long, long read: https://www.northamericanmotoring.co...-solution.html
Bottom line is that the fan is supposed to come on at low speed when you turn on the A/C (and/or when the coolant reaches a certain temperature). When the low-speed fan circuit is working, you'll barely hear it. If it's not functioning (as with the burned out resistor), the coolant temp eventually gets hot enough to kick on the high-speed fan circuit, which then cycles on and off with the changing coolant temps (all of which has nothing to do with your A/C being switched on).
Yes, the power steering fan should come on with the low-speed radiator/coolant fan, but the dealer recently told me that they're not related or connected circuit-wise.
rikaro
Aug 7, 2021 02:33 PM
Melvinyip
Apr 17, 2020 09:28 AM
Rgoodwin
Tires, Wheels, & Brakes
Apr 21, 2017 10:56 AM
Marco Guardado
Sep 15, 2015 01:22 AM
damncajun
Aug 17, 2015 08:25 PM
