R50/53 Tire Sizes
Old Apr 17, 2015 | 08:39 PM
backsidedriver's Avatar
backsidedriver
Tire Sizes
I have a 2004 R50 Cooper that currently has 175/65R15 tires. This is a limited supply tire size. However, 185/65R15 tires are more common. Wondering if anyone has tried putting a larger tire on their mini and what their experience has been?
Old Apr 17, 2015 | 09:28 PM
bjcarter2's Avatar
bjcarter2
Play with this calculator to find a more readily available substitute.
http://www.tacomaworld.com/forum/tir...5r15-185-65r15
That said; the 185 will result in a slighter lower RPM at highway speeds - better fuel economy too. If I were in the market, I wouldn't have an issue making the change.
But, you lose a little bottom end grunt. If you're not a spirited driver, you'd likely not notice the difference.
Old Apr 18, 2015 | 04:58 AM
cristo's Avatar
cristo
Alliance Member
185/65/15 works fine. So does 195/60/15. I have used both for winter tires, currently have 185/65/15.
Some use 205/55/15 but I think that's getting just a little wide for a 15x5.5 wheel.
Old Apr 18, 2015 | 07:09 AM
shipjumper's Avatar
shipjumper
185/60/15 is actually within 1mph of that.
I ran them on my clubman before trading it in on my Checkmate.
Old Apr 18, 2015 | 07:35 AM
cristo's Avatar
cristo
Alliance Member
Yep, forgot 185/60/15. That's good, too.
Old Apr 18, 2015 | 08:13 AM
hsautocrosser's Avatar
hsautocrosser
The Michelin Pilot Sport A/S 3 is an awesome 175/65-15 tire.
Old Apr 20, 2015 | 07:45 PM
backsidedriver
Thanks for all the replies. the information is very useful. Sounds like i would be good with 175/185/195/205
Old Feb 13, 2016 | 06:28 PM
backsidedriver
So i know i posted this a while ago but i am now at purchase time. Looking for recomendations. Would you go with the spec'd 175/65/15 or would you go with 185/65/15? Does one provide a better ride over the other?
Old Feb 13, 2016 | 06:53 PM
cristo's Avatar
cristo
Alliance Member
185/65/15 would be a smidge softer (taller sidewall) and a smidge better handling
(wider tread), all other things being equal (which they often aren't). Would also
make the speedo slightly more accurate than stock (won't over-read actual speed
quite as much).
Kimolaoha
Dec 5, 2020 09:32 PM
kazyn
Oct 25, 2019 02:34 PM
Waszak
Oct 21, 2017 05:55 PM
col127
Aug 21, 2015 02:11 PM
Edgar78
Aug 15, 2015 05:33 AM
