Drivetrain Best plug for JB+
Old Apr 16, 2015 | 06:21 AM
rckrzy1's Avatar
rckrzy1
Best plug for JB+
Ok, wife has owned to 2 MINI's, 2011 MCS and now a 2012 R57 , both with JB+ and both around 34-36K suffered a dropped plug, ie insulator cracked and dropped causing missfire , research says spark knock , should we be running 1 colder or hotter in hopes of not repeating or is 30K a good time to just replace plugs as PM ?
Old Apr 16, 2015 | 08:22 AM
MiniSkoon's Avatar
MiniSkoon
I've emailed BMS asking them if 1 step colder is needed. I only have the JB+ on a '12 MCS. They said it wouldn't hurt but not totally necessary with my set up. I think unless your putting out a lot more hp over stock (50+,) it isn't a must.
Old Apr 16, 2015 | 08:26 AM
rckrzy1's Avatar
rckrzy1
Trying to avoid getting stranded again in the future.
Old Apr 19, 2015 | 10:13 PM
holkki's Avatar
holkki
Just now I try to get find Citroen DS3 Racing plugs (part no.9677446980) type NGK IR ILZKR8C8G. One degree colder than JCW plugs (..KR7..) ,recommended modified N14/N18,but little hard to find....
Old Apr 20, 2015 | 10:38 PM
johntotah94's Avatar
johntotah94
Ngk ilkr8e6
Old Apr 21, 2015 | 02:29 AM
holkki's Avatar
holkki
Yep,Johntotah 94, you're probably right, cheaper and easier to find! But what else is different, only cap? heatrange is same.
Old Apr 22, 2015 | 12:45 PM
johntotah94
I thought stock heat range was 6 and the NGK ILKR8E6 is a 8 heat range.
I used the stock plugs with the JB+.
The stock Beru Plugs were crap when I got a tune. Could not handle the higher boost.
The ILKR8E6 are from a Mitsubishi Evo and they can handle a lot of boost.
Old Apr 26, 2015 | 08:28 PM
Indimanic's Avatar
Indimanic
I hear the NGK plug can crack the insulator under higher boost. Was your plug a NGK?
My recent Brisk Silver plugs melted after 4k miles
Trying the Denso now.
Old Apr 29, 2015 | 02:01 PM
holkki's Avatar
holkki
This is why I ordered the Citroen DS3 racing spark plugs, factory tuned N14 motor.Plugs type is NGK IR ILZKR8C8G, one degree colder(8) than JCW plugs.Hard to find,Citroen OEM parts,not possible aftermarket selling in some countries.I found mine on Ebay...
Old Apr 29, 2015 | 02:43 PM
malibujoey's Avatar
malibujoey
Have a 11 JCW. Why is colder recommended? What's the diff?
Old Apr 29, 2015 | 10:24 PM
holkki's Avatar
holkki
-If you do not have mods under hood,you don`t need colder plugs."Heavy mods", more boost , aggressive tune etc .and a lot of increase in power then you may need colder plugs.
Old May 6, 2015 | 08:30 PM
rckrzy1's Avatar
rckrzy1
Ok, got some new NGK IR plugs in heat range 8 from my local manic tune guy who says these are best for high boost , now my problem is that I have thin wall 14mm 12pt BUT these plugs are 5/8" 6 pt , do I have to find a thin wall 5/8" ? Anyone know exactly how small the N18 hole is for plugs ?
Old May 8, 2015 | 12:43 PM
Tigger2011's Avatar
Tigger2011
Alliance Member
Another option if you want to stick with a 12 point is the NGK ILZKBR8C8S. They have been successfully used in the past. The dimensions are correct for our application and were originally designed for the BMW F30. What they are not however is cheap. Expect to pay ~$75 for a set.
Old May 22, 2015 | 12:40 PM
devicemanager's Avatar
devicemanager
Terry recommends the NGK 5992 for the N18 gapped at .022" (out of the box it's .032").
http://www.burgertuning.com/mini_coo...t_adapter.html
Old May 23, 2015 | 08:37 PM
Terry @ BMS's Avatar
Terry @ BMS
+1
Old Nov 13, 2015 | 12:24 PM
Arthas's Avatar
Arthas
ILZKR8C8G from RCZ-R or the ILKR8E6 from Evo better for N14 JCW?
Filmy
15
Jun 6, 2023 06:27 AM
Accessory Products
Sep 11, 2015 08:01 AM
Sep 11, 2015 08:00 AM
Filmy
Sep 7, 2015 08:27 PM
Sep 4, 2015 03:56 PM
