Boost problems
Old Apr 14, 2015 | 04:18 PM
micromini234's Avatar
micromini234
Boost problems
Im at loss does anyone have any ideas to solve this problem.
Today when I was trying to merge onto the highway, I floor'd my pedals, and at about 16-17psi I got this thumping- like its gonna stall or maybe a misfire.
This was also followed with a loud pop and a lot of burning oil out of my exhaust. My boost gauge and such also went out of wack. After a code clear everything went back to normal- no boost leaks- but I manage to pull a p0130 misfire. Ive been trying to replicate this and the cel hasnt popped up again. The thumping on the other hand has.
My mini is modified but I dont think its ever done this before. I did recently change the plugs about 3 weeks ago to platinum-one step colders. But I can seem to remember if this was happening before the plug change.
Old Apr 21, 2015 | 08:33 AM
nkfry's Avatar
nkfry
Sounds like you have to contact Evolve, did you get a flashloader with your tune? You may need to take a log and send it to them for evaluation.
Phone:586-792-6464
Info@DetroitTuned.com
Nick@DetroitTuned.com
Old Apr 21, 2015 | 09:36 AM
Saltysalt's Avatar
Saltysalt
turbo blown.....
Old Apr 21, 2015 | 01:48 PM
Grizld700's Avatar
Grizld700
When it did the thumping, was it similar to several little clicks then a large puff of black smoke out the exhaust? If so, I can duplicate this concern on my car. I have to have it in a higher gear (5th or 6th) and driving 40-50mph; slight incline and then WOT and then click click click; momentary loss of power as the same time; then a large puff of smoke out the exhaust; Normal after that.
I have trained my self to down shift more often and leave it in lower gears until cruising. Or just don't go WOT at the wrong time. I have to get to a dyno and get my A/F's logged and adjusted and I should be good. It's just getting this done. It's hard to get on a dyno where I live, not much around here.
I would do what nkfry said and get logs sent out to Evolve so they can modify your A/F ratios.
Again, thats if you're experiencing the same thing I am.
Old Apr 22, 2015 | 06:08 AM
micromini234
It wasn't really clicking it was more like thumping stall type.
I was able to diagnosis it- apparently this is because of the platinum spark plugs I used. The gapping is to big on them. Sent from iPhone
rob&JCW
Feb 13, 2023 07:03 PM
AdrenaliNate
Nov 4, 2015 07:26 PM
PEterChoqu
Aug 26, 2015 08:33 AM
Indimanic
Aug 19, 2015 11:08 AM
Ambient Thermal Management
Aug 7, 2015 12:27 PM
