R50/53 gas computer
Old Nov 7, 2002 | 08:03 AM
mmmark's Avatar
mmmark
I had a fright this morning on my way to the gas station. When I got home last night the computer said I could go another 15 miles on the remaining fuel--ample enough to get to the station. But on the highway, suddenly the mileage started dropping fast, and about two miles from the gas exit it read 1, then dropped to 0! I thought for sure I'd be walking, but suddenly the number darted up to 3 then wavered back and forth between 0, 1, 2, 3, and I made it to the pump. I think I put in about 12.4 gallons.
What's my point here? I'm not sure, but I think it's don't count on the computer's accuracy at the bottom end of the tank.
Of course, it's bad practice to let the tank get that empty anyway. The crud at the bottom of the tank can really mess up the injectors.
Old Nov 7, 2002 | 08:06 AM
minimotorin's Avatar
minimotorin
I think you answered your own question, don't drive until your tank
is almost empty. Bad for MINI motor!!!
Old Nov 7, 2002 | 08:21 AM
Mini2Go's Avatar
Mini2Go
Coordinator :: Pitt Stop MINI
True. Don't run it empty.
Old Nov 7, 2002 | 08:23 AM
Babs's Avatar
Babs
Also, on cars with the fuel pump inside the fuel tank, repeatedly running the tank low can cause the fuel pump to burn out. The pump relies on the gas in the tank to keep it cool. I don't know if the MINI's pump is internal or external, but the manual says not to run it lower than a range of 35 miles = approx 1 1/2 gallons.
Old Nov 7, 2002 | 08:25 AM
8ball's Avatar
8ball
You have 'crud' in your tank already? this is a new car, yes?
but seriously, most tanks have a 'thermister' that is used to triger the warning at end-of-tank; when fuel gets low, it splashes on the thermister (which is usuall submerged in fuel) so it doesn't know if there is fuel or not, or how much.
Old Nov 7, 2002 | 11:29 AM
Rocketboy_X's Avatar
Rocketboy_X
The manual also states that running low on gas frequently can ruin your catalytic converter...
and don't you mean the crud floating on top of the gas? One would think that the outlet of the tank would take fuel from the bottom of the tank, not the top...
Rocketboy_X
Old Nov 7, 2002 | 11:42 AM
Davbret's Avatar
Davbret
Heads up!
Don't even think about driving aggressively when it shows you have 25 miles left and under. Take it from me. It was showing 23 left and then I took a hard right hand turn...then the car puttered to a stop and wouldn't restart. Drive like a granny on valium when it gets this low or suffer the same fate I did.
FYI.
R
Old Nov 7, 2002 | 11:47 AM
8ball's Avatar
8ball
>>....and then I took a hard right hand turn...
... i've never known you to drive like that ...
Old Nov 7, 2002 | 12:04 PM
npartist's Avatar
npartist
Hey to break it to you but the myth about stuff in the bottom of the tank "hurting" the engine at stuff is a lie. All gas tanks have the exit (to the engine) at the bottom. As for stuff floating on the top of the gas, maybe but not likly due to the fact that gas is not very dense (water sinks in it). But running on fumes has to be bad somehow.
Old Nov 7, 2002 | 05:05 PM
Davbret's Avatar
Davbret
R
Old Nov 7, 2002 | 05:22 PM
2minis's Avatar
2minis
I don't have a gas computer. I have a needle and when it gets halfway between
E and F I go to the gas station.
Old Nov 7, 2002 | 05:32 PM
Indy_Archy's Avatar
Indy_Archy
Something you are all forgetting is that gas is a fluid substance. If you take a hard right, the gas will all go to the left, and if it is low enough, will stop going into the fuel pump, causing a stall. Same with accelerating, going up or down a steep hill, etc.... on a low tank. I tend to agree with 2 minis. Just don't let tank get low.
Old Nov 7, 2002 | 09:32 PM
Zappa's Avatar
Zappa
Also... There is a 2 gal reserve that does not register,... So figure at least 30 miles for emergency!
Old Nov 7, 2002 | 09:53 PM
Chuckster's Avatar
Chuckster
Mini's like a full tank, don't you?
Old Nov 7, 2002 | 09:59 PM
Zappa's Avatar
Zappa
Chuckster?? You aren't the Chuckster from the Corvair Group are you???
scfiveo
Sep 27, 2019 02:27 PM
OutMotoring
Mar 3, 2017 06:29 AM
bahman
Feb 14, 2016 10:29 AM
vulkandino
Oct 31, 2015 08:29 PM
madmix
Oct 5, 2015 09:58 AM
