R56 R56 lowering and wheel size
Old Mar 30, 2015 | 09:41 AM
Suprememrvn's Avatar
Suprememrvn
Hello all,
I just got a r56 for my birthday, and I'm thinking of adding new wheels and dropping the car..
How low should I drop? Any good brands for a decent price?
What size rims should I get? I'm thinking 18s. But opinion always matter
Thanks!
Old Mar 30, 2015 | 11:43 AM
isamin's Avatar
isamin
I'm planning to do the same and based on my research (still missing my final measurements) I feel I could go with 17 x 7.5 Rota RB wheels with Mach V springs on 235/40/17 Sumitomo tires. MINI is a 2013 JCW so I know I'll need spacers for the brakes (have a 4pc set of 20mm's). Anyone feel I won't be able to pull this off or have you done something similar? Thanx for your input.
ISAMIN
Old Mar 30, 2015 | 02:41 PM
Suprememrvn
ISAMIN
I was going through some threads and I guess ill just go with H&R coil overs.
18s with offset looks pretty nice
Old Mar 30, 2015 | 09:07 PM
cb_smalls's Avatar
cb_smalls
Rotiform just re instated there cast line if BLQ's and turomac's. A lot of people ran the 17x8 et30
For an awsome square fitment. The set will run you right at 1k. As for lowering were you thinking coilovers or springs? I myself am going to run CAtuned flagship coils which you can purchase from there website but I see a lot of people on swift springs that really like the look. I guess it depends on how low you want to go and how aggressive you want your fitment
Old Mar 31, 2015 | 03:54 PM
mcc21's Avatar
mcc21
ISAMIN
235/40/17 might be too thick for those rims. many people run 215/45/17 to match the stock mini settings.
also if you are buying new rims, might as well find the rims that fit the offset without spacers. unless you can score a set of nice used rims then you might need to use spacers.
Old Mar 31, 2015 | 04:40 PM
ASuman's Avatar
ASuman
I am running 17X7.5 245/45/17 The car is running H&R Coils and the Koni Yellow shock/struts. Works great I have a 2011 R56 JCW
thebordella
Aug 31, 2015 01:37 PM
Mini'mon
Aug 16, 2015 04:15 PM
Rennfahrer555
Aug 13, 2015 09:07 AM
