R50/53 Painting door trims?
Old Mar 26, 2015 | 01:20 PM
rikaro's Avatar
rikaro
Hi guys. I want to repaint my door trims (handle and the "ring" around it) but I couldn't find any diy on removing the ring since it's plastic welded.
I suppose one can drill the plastic welds out, repaint, then assemble again with some sort of glue?
Any suggestions?
stolen mathen001's photos but I wanted to respray into a different color
Old Mar 26, 2015 | 01:30 PM
FatherG's Avatar
FatherG
I would not recommend removing them. Pulling them will eventually strip out whatever you use to replace the weld. I wanted to do the same with mine but decided not to.
Old Mar 26, 2015 | 02:07 PM
rikaro's Avatar
rikaro
I found a similar way from a fiat page.
http://www.fiat500usa.com/2012/10/fi...oor-panel.html
Time to get to work.
@fatherG thanks for the suggestion but i wasn't planning to take no for an answer :P
Old Mar 26, 2015 | 03:57 PM
rikaro's Avatar
rikaro
I took the first piece off. Accidentally drilled through one of the holes but it doesn't matter since I can cover it up with plastic filler before I paint
Old Mar 26, 2015 | 04:32 PM
FatherG's Avatar
FatherG
So, keep us apprised of the progress. I am curious to see how you re-attach them as I may yet do the same with mine.
Old Mar 26, 2015 | 04:37 PM
rikaro's Avatar
rikaro
I'm going to see if i can seal it with silicon. I'll just get new panels if all else goes wrong but it should be fine.
Old Mar 26, 2015 | 06:44 PM
Filmy's Avatar
Filmy
IIRC, the coating on the dash and door "rings" is not what you think it is. I think it's some sort of vinyl coating or wrap. I see that others have painted theirs, but make sure you first put down a coat of something that won't cause that original coating to wrinkle/dissolve/worse.
Old Mar 26, 2015 | 09:14 PM
FatherG's Avatar
FatherG
I painted my dash in a hammered finished paint and the rings in Chili red which the local auto paint house made up for me. I did sand the original finish off before priming and painting. See my Gallery.
The original silver is very thin and sand easily.
Old Mar 27, 2015 | 07:28 AM
Saltysalt's Avatar
Saltysalt
so many people have painted rings, did they just mask them up and spray? I thought they would be able to come out
Old Mar 27, 2015 | 08:50 AM
Eric_Rowland's Avatar
Eric_Rowland
I had a passenger accidentally rip out the door pocket (no, it's not a door pull ) and re-attached it with a glue gun. Been fine for years, and I don't expect any issues. IIRC, others who removed the trim used this method.
Old Mar 27, 2015 | 05:08 PM
rikaro's Avatar
rikaro
The huge ring trim (the one that circles around the whole panel) does look like there's a vinyl coat on there. I'm still thinking what to do with it. Sand + primer + paint? or just use something like plastidip? I personally want to stay away form plastidip if i can.
Old Mar 27, 2015 | 05:12 PM
rikaro's Avatar
rikaro
Update: Painted and silicon sealed it back in place. Will check how strong it is after it dries up.
Attached Thumbnails Painting door trims?-20150327-matt-kwok-r53panel-1.jpg   Painting door trims?-20150327-matt-kwok-r53panel-2.jpg
Old Mar 27, 2015 | 06:32 PM
FatherG's Avatar
FatherG
Are you only going to take the ovals/speaker covers off and not the actual pull/armrest bars off? In that case - I guess silicone will do. I was thinking that you are removing the armrest bars too.
Old Mar 27, 2015 | 07:53 PM
rikaro's Avatar
rikaro
If you look at the pics, I've taken everything apart. I just start putting back the easier stuff first
Old Mar 30, 2015 | 11:35 PM
rikaro's Avatar
rikaro
So everything is back into place. So far so good. My suggestion is to use a good amount of silicon for the bottom piece. The reason is because the top piece is held up with bolts but the bottom isn't. Putting more would be safe just incase someone decided to close the door pulling the "storage" piece.
Old Mar 31, 2015 | 07:36 AM
FatherG's Avatar
FatherG
That looks REALLY good! Nice work.
Two questions:
1) Did you simply drill out the welds? What size bit?
2) Can you can the ovals off without removing the bars?
Ok, actually three questions.
Old Mar 31, 2015 | 08:44 AM
Eric_Rowland
How did you prep?
What did you paint it with?
(that's a total of five questions if you're keeping track. )
Old Apr 1, 2015 | 12:32 AM
rikaro's Avatar
rikaro
Two questions:
1. Yes just drill out. Be careful not to drill to much otherwise it will go through the panel. I used the biggest drill bit I have. Don't remember the size but anything close to the size of the plastic welds will do. After all is drilled then push it through the drilled holes with a screwdriver until they pop out. The bottom piece has 3 long plastic welds. Using a cutter should be able to get them off but be cautious not to cut yourself.
2. Yes but I removed everything because it's the bars on mine that are worn
Originally Posted by Eric_Rowland
How did you prep?
I just found whatever is in the house to prep. Sand with 320 grid, primer then texture paint. The texture paint is aweful because they would wear prematurely when touched all the time but that's all I had at home at that time.
Old May 9, 2015 | 06:14 PM
roll_the_dice's Avatar
roll_the_dice
Nice job. I am wanting to do the same thing except I want to wrap my trim in real carbon fiber and repaint the actual door pull in gloss black. So my questions is this:
When you removed the door trim was it 3 pieces or 2?
In other words, was the top arch attached to the door pull or are those pieces separate?
Thanks for any insight you might give.
David Eric Rosenberg
R57 :: Cabrio Talk (2009+)
Sep 10, 2015 12:34 PM
Filmy
Sep 7, 2015 08:27 PM
Southern Marylander
Sep 3, 2015 05:46 AM
tag1260
Sep 2, 2015 07:42 PM
spackletooms
Sep 1, 2015 10:12 PM
