FS:: PRW 2510901 FluidGel Black 8.7... PRW
Old Mar 26, 2015 | 10:35 AM
crankshaft's Avatar
crankshaft
Price: $195
Location (Region): Midwestern
Item Condition: Brand New
Brand new, bought for a car that I traded before install.
Retail for $245
Old Mar 27, 2015 | 12:33 AM
eMINI of the State's Avatar
eMINI of the State
looks like it has some wear and tear? how many miles are on it? I have an SFI currently. Is this one a reduction version? If so, is it an 8.7%? that seems like a lot if it is. Get back to me and maybe we can make a deal
Old Mar 27, 2015 | 04:12 AM
crankshaft's Avatar
crankshaft
It's new, never installed. The flash make it look like that.
Yes it is the 8.7% reduction.
Old Mar 27, 2015 | 04:39 AM
eMINI of the State
wait reduction? whats the benefit? i was thinking overdrive
Old Mar 27, 2015 | 04:55 AM
crankshaft's Avatar
crankshaft
It is 8.7% reduction so it's an under drive. It is a pound lighter than stock but a fluid sfi damper. With this reduction you need to match the correct SC pulley to get the numbers you want.
If you go over sized you will spin everything to fast and burn up your altenator.
Old Mar 28, 2015 | 06:34 AM
DixonL2's Avatar
DixonL2
Reduction was for the Justa-Cooper (non-S). Less rotating mass, under-drive the alternator and waterpump to free up some hp. Reported to work very well. Friend of mine has the standard one for his "S" and likes it a lot, and he's really picky. I've got a standard on order for my "S".
I suppose if you do the math you can use a reduction pulley (15-19%) and recoup some boost from the s/c, but you'd be on your own to size the belt. With a stock s/c pulley you'd be running lower boost. I think the math would be straightforward, -8.7% and run a 19% s/c pulley = the same a running a +10% pulley (if one were available) on a regular crank pulley, but I may be mistaken there...
boostedhaze
Jan 2, 2018 07:26 PM
G1HQ
Dec 7, 2015 02:23 PM
WayMotorWorks
Aug 4, 2015 01:47 PM
