Turbo Inlet
Old Mar 26, 2015 | 09:10 AM
York's Avatar
York
Turbo Inlet
Anyone know if I purchase just this rubber spool piece on the turbo inlet? As you can see this one is damaged.
Old Mar 26, 2015 | 12:55 PM
afadeev's Avatar
afadeev
Attachment 108107
No, doesn't look like that part is sold individually from the turbo itself:
http://www.realoem.com/bmw/showparts...=11&fg=50&hl=1
What did drop on it to crack it ?
a
Old Mar 26, 2015 | 01:39 PM
York's Avatar
York
Thanks for the info. The damaged part is a black plastic spool that stayed on the inlet when I removed the inlet pipe, I think it just deteriorated from time, heat and oil.
Old Mar 26, 2015 | 02:08 PM
Grizld700's Avatar
Grizld700
+1 Moderately common
Check this part out:
It's a bit tricky to get on but its a very nice replacement
HERE is a link
Old Mar 26, 2015 | 02:15 PM
York's Avatar
York
I like that!
Old Mar 27, 2015 | 08:33 AM
If intake boot it cracked on the small gasket and the main boot has a crack ( seen it on mine before ), you will have to get the whole tube. Which when you replace will be fine and seal. Clean up the oil residue on the flange and they slide it on all the way.
13717555784 ribbed version N14 Cooper S .
http://www.ecstuning.com/Search/SiteSearch/13717555784/
And a new clamp for that turbo inlet connection , the old ones can bend from over clamping on / off all the time and the tube works it way off.
http://www.ecstuning.com/Search/SiteSearch/13717577548/ES35254/
Old Mar 27, 2015 | 08:47 AM
York's Avatar
York
Thanks! Just removed the inlet tube, the turbo end is disintegrating. I have it taped up for now. Just installed a new vacuum pump that I purchased from you. Guess I will put inlet tube on the list.
The old pump:
Old Mar 27, 2015 | 08:55 AM
Welcome. Just keep an eye on that tube so it does not slide off or work its way off.
Thanks for the orders.
Old Mar 27, 2015 | 10:25 AM
York's Avatar
York
Not sure there is anything wrong with the vacuum pump but I did find that the small vacuum line was separated from the hard tubing so it was a worthwhile project.
Old Apr 21, 2015 | 08:39 AM
nkfry's Avatar
nkfry
Our heat/press turbo inlet flange will be cheaper cost than buying a whole intake pipe, as well as keep the intake pipe from slipping off the turbo as many cars have issues with.
Turbo Inlet Flange
Nick
Detroit Tuned
Phone:586-792-6464
Info@DetroitTuned.com
Nick@DetroitTuned.com
Old Apr 21, 2015 | 08:53 AM
Grizld700's Avatar
Grizld700
Turbo Inlet Flange
Nick
Detroit Tuned
Any tricks to getting this installed. I've had mine for a few weeks now. Cold engine, heated the piece in the oven like instructions said, but still couldn't get it on all the way. It went on about an inch and stopped.
Old Apr 21, 2015 | 09:52 AM
nkfry's Avatar
nkfry
We've had the best luck by using a MAP gas torch, heating the flange to around 180-200* grabbed it gently with a pair of channel locks and slipped it onto the compressor inlet. It should slip right on, hold it there for a few seconds and it should cool rather quickly with the turbo acting as a heatsink.
Phone:586-792-6464
Old Apr 25, 2015 | 10:07 PM
Systemlord's Avatar
Systemlord
Turbo Inlet Flange
Nick
Detroit Tuned
Hay Nick can this flange be used on an 07 MCS so I can get the plastic hard pipe (JCW N14) to fit onto my little turbo?
Old Apr 27, 2015 | 06:37 AM
Grizld700's Avatar
Grizld700
I have the flange for my '07, and I have the JCW hard pipe. So "Yes!" is the answer. In fact you can use the JCW hard pipe without the flange. All you have to do is transer the inner seal from the stock rubber tube to the JCW hard pipe. But for extra security, I'd get the flange.
Old Apr 29, 2015 | 09:20 PM
MINeclair's Avatar
MINeclair
I got the DT flange and had the same problem. Heated it with a torch too. The turbo is too much of a heat sink- as soon as it touched the flange, the flange gripped the turbo and got stuck. Had to cut mine off with a dremel since it was only part-way on and I couldn't torch it again in the engine bay.
Old Apr 29, 2015 | 10:34 PM
Systemlord's Avatar
Systemlord
I assume the correct way to install the flange is when your turbo is cold?
Old Apr 30, 2015 | 07:51 AM
Grizld700's Avatar
Grizld700
How long had it been since you drove your MINI when trying to install this?
Old Apr 30, 2015 | 08:58 AM
MINeclair's Avatar
MINeclair
It had been a few days since I drove the car. The turbo was completely cold. You can see the mark of how far I got the flange to slide on in the pic.
NYMADMINI
Dec 14, 2016 02:33 PM
gar56
Nov 15, 2016 06:41 AM
Joeygonz
Oct 4, 2015 09:25 PM
Levers_and_Gears
Sep 28, 2015 04:42 PM
EVMini
Sep 28, 2015 10:20 AM
