205 55 16 & TSW Springs
Old Mar 23, 2015 | 08:29 PM
MothAudio's Avatar
MothAudio
Since the ride height of a 205 55 16 tire is taller than my stock 195 55 16 tires will this be too tight with TSW springs on a '09 Clubman. Looking to reduce the wheel gap and I need new rubber. Other mods to follow include WMW bump stops / KONI FSD Shocks and TSW 19mm rear sway bar. TIA.
Old Mar 24, 2015 | 06:31 PM
minihune's Avatar
minihune
OVERDRIVE - Racing Champion
Look at your current tires and see how much clearance you have now if you are already on TSW springs. If the springs are not yet on the car you can ask Way at Waymotorworks if he has seen 205/55-16 tires on TSW springs on a clubman.
Compared to 195/55-16 on OEM rims-
205/55-16 is 5.5mm taller in diameter
Note that tread block design on the new tire's shoulders will affect clearance to the wheel arch plastic. Max Summer tires come with a broad large shoulder block that can be more squared while All Season tires may come with a more rounded shoulder tread design.
Old Apr 2, 2015 | 03:27 PM
MothAudio's Avatar
MothAudio
Thanks. I've decided to go with the 205 / 50 / 16 Continental ExtremeContact DWS instead.
Steffen.Johnson
42
Jan 25, 2023 02:47 PM
CooperSharp
Oct 12, 2015 09:21 AM
Suspension Products
Oct 1, 2015 11:53 AM
Suspension Products
Oct 1, 2015 11:14 AM
nshannon29
Sep 30, 2015 05:21 PM
