WTT:: 949 6uL 15x9 et 36
Old Mar 22, 2015 | 10:00 AM
ottawa's Avatar
ottawa
WTT: 949 6uL 15x9 et 36
Category: Wheels & Tires
Price: $1
Location (Region): SouthEast
Full set of GEN IV 949 6uL's (9/10 condition)
Et36
15x9 = 12lbs
15x8 = 11.5lbs
Silver finish
aluminum dual valve stems
carbon fiber wheel cap.
(Will fit most Honda and Mazada)4x100)
225 Hankook Rs3 rubber (60ish% life left (slight camber wear on rear))
I'm shortening my gear ratios and perhaps need a slightly larger rim for my car. to offset this ( ONLY REASON IM CONSIDERING THIS ). I really, really enjoy this set up for track/daily use. This set up really aids in negating understeer and has loads of mid apex grip.
Let me see what you guys have out there!!
I'm looking for other lightweight track/daily combos. Either 16-18 and must be 8-10 wide. Not looking for MINI OEM wheels.
thanks you for looking.
TO reach me quickly please send an email to Irkath69@gmail.com
Attached Thumbnails 949 6uL 15x9 et 36-1907400_709582042429959_6626842557465954748_n.jpg   949 6uL 15x9 et 36-phone126_zpsd1d859d8.jpg
Last edited by ottawa; Mar 24, 2015 at 05:04 PM. Reason: price (looking to trade) not sell.
Old Mar 22, 2015 | 11:42 AM
ottawa's Avatar
ottawa
Item is located in tampa, fl
Old Mar 24, 2015 | 04:08 PM
MyFirstR53's Avatar
MyFirstR53
GLWS, I use this same wheel setup for HPDEs and would recommend them to all mini owners
Old Mar 24, 2015 | 04:33 PM
ottawa's Avatar
ottawa
Thank you.
Hopefully some one who knows its worth is lurking. Theyre on back order for months... even if you wanted to get these, you couldnt.
Old Mar 24, 2015 | 04:57 PM
JohnDoe11's Avatar
JohnDoe11
Originally Posted by ottawa
Thank you.
http://949racing.com/ Has the 8 in stock and the 9 coming in for the end of next week. New 225 Hankook Rs3s are a little less than 600 shipped so you're saving anywhere from $200 - $275.
Just a heads up.
GLWS!
Old Mar 24, 2015 | 05:01 PM
ottawa's Avatar
ottawa
Just a heads up.
GLWS!
Right on, most of the time the orders do get pushed back. Im not looking to sell these what so ever. I had to put a price to make the add. Im only looking to trade them for somethong else comperable ina larger wheel diameter.
in fact, let me adjust that. I bet half the people dont even read the add. Just skim price.
Old Apr 2, 2015 | 08:30 PM
mini_racer's Avatar
mini_racer
Did you need ~15mm spacers for these to clear the rear trailing arms? but maybe using 20mm as that size is more readily available?
Old Apr 2, 2015 | 08:37 PM
ottawa's Avatar
ottawa
I only needed a 5 mm spacer for front. The rear cleared with out a spacer.
my car is also sittong on coilovers.
Old Apr 2, 2015 | 08:57 PM
mini_racer's Avatar
mini_racer
Wow, really? Huh, I need a 5mm in the back for my 6ul 15x8s to clear the trailing arm. It is curious that you only need 5s in the rear, and yeah I am on coilovers as well.
Old Apr 25, 2015 | 06:13 PM
SOOPER_S's Avatar
SOOPER_S
are the for trade only or do you have a sale price?
Old May 3, 2015 | 05:09 PM
rudnimark's Avatar
rudnimark
MiniMio
Tires, Wheels, & Brakes
Dec 24, 2017 10:30 AM
Dino S
Dec 7, 2014 01:53 PM
piston
Nov 18, 2013 12:31 PM
irishpunk
15
Oct 22, 2011 09:02 AM
