R50/53 2006 r53 with dreaded PS leak..
Old Mar 20, 2015 | 08:21 PM
Steffen.Johnson's Avatar
Steffen.Johnson
I threw my car Barnaby 2006 MCS r53 up on jacks today for the first time since I owned it and noticed a large PS leak. I am under the impression that 2006 was the year they "fixed" the leak so it is NOT covered under warranty by MINI..is this correct? If what my MINI dealer tells me is true and I need to get it fixed on my own where is the first place to start on this?? HELP
Old Mar 20, 2015 | 08:46 PM
gpwpat's Avatar
gpwpat
Leaks are not covered for any year. Probably the hoses to the reservoir. They don't cost a lot to replace yourself. I just replaced my supply line.
Old Mar 20, 2015 | 08:57 PM
Steffen.Johnson
The 2002-2006 r53 were covered under warranty by MINI. But of course my year isn't included haha
Old Mar 21, 2015 | 06:40 AM
Noir2005's Avatar
Noir2005
I just purchased the necessary hoses to have my pump replaced. I found the inlet tube for about $41 (MINI O.E.) on eBay, and ordered the rest through FCP for about $70. You'll need the return hose, the two washers, banjo bolt, and because I like an original look, I ordered their crimp style clamps, though you need a special tool. It'll take a few hours at the most if your working in your driveway. Go onto realoem.com, you can get the o.e. part numbers.
Old Mar 21, 2015 | 08:34 AM
JAB 67's Avatar
JAB 67
Good luck trying to install the OE crimp style clamps without dropping the subframe.
Old Mar 21, 2015 | 09:02 AM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
Start with replacing the inlet hose with new clamps
The extended warranty from MINI for power steering pumps was for them being inop no leaking. And for MINIs produced prior to Feb 05.
Old Mar 21, 2015 | 10:16 AM
ZippyNH's Avatar
ZippyNH
no....ONLY the pump was warrentied...the ps lines are the same...they leak the same...
Old Mar 22, 2015 | 08:18 AM
Steffen.Johnson
Thanks will do, I take it you have to drop the subframe for this job right?
udenmjc
Aug 26, 2015 01:06 PM
greekzilla
Aug 23, 2015 03:44 PM
missinmyjeep
Aug 22, 2015 07:13 PM
elightbo
Aug 17, 2015 01:50 PM
