R52 2005 R52 LED lighting - Can Bus required?
Old Mar 16, 2015 | 03:24 PM
Reilley's Avatar
Reilley
I've searched through several pages of R52 threads but didn't see a thread dedicated to LED upgrades, so I apologize in advance if I missed it!
I started updating the stock incandescent lighting with LEDs and thus far have only used CanBus lighting on the exterior, replacing the side markers, license plate, and front parking lights. So far, these have worked very well. I will eventually swap out the turn signals, tail lights, backup light, and pssibly the side markers.
Now I want to tackle the interior, but here's my question:
Should I continue to use CanBus bulbs as I did for the exterior? Common sense says yes, but I've heard rumor that this wasn't necessary. I don't mind the extra cost at all.
Also, does the dome light require two bulbs?
Thanks!
Old Mar 19, 2015 | 12:51 PM
We use those Ziza bulbs with those resistors as they will not flicker or throw a code on the outside. On the inside some led bulbs flicker or just don't work with the voltage and LKM " light control module .
We have the Ziza kits here for the R52 and they look great and match in output.
Install pdf is linked on the main master kit.
http://www.ecstuning.com/News/MINI_R...006_2007_2008/
Good luck.
Old Mar 20, 2015 | 09:06 AM
Reilley's Avatar
Reilley
Thanks!
Awesome - thank you! I will check them out now.
Old Mar 20, 2015 | 10:24 AM
You are welcome.
Old Mar 20, 2015 | 10:32 AM
rckrzy1's Avatar
rckrzy1
Inside I just bought from china, no can bus and NO problems, spent like $20 total to do all of them.
Old Apr 11, 2015 | 04:06 AM
brightstar's Avatar
brightstar
Awesome, have you full images of that car i want to see hope that you should share hare many members of this forum to see and check out it
Old Apr 13, 2015 | 05:20 AM
Pics posted above and linked.
Old Oct 1, 2020 | 07:11 PM
Tombstone's Avatar
Tombstone
Blue Led?
Good luck.
Does this kit come in the blue led lights? Thanks
Old Oct 6, 2020 | 07:08 AM
Its the stock color that looks the best, its a white/blue closest to the newer MINI led interiors. We dont have any other colors at this point as this color provide the most useful light. Start doing blue and red and the light output goes down and you cannot see too well.
mdutton11
14
Oct 26, 2015 01:47 PM
HCClubbie47
R55 :: Clubman Talk (2008+)
Aug 24, 2015 02:16 PM
I_drive_slow
Aug 18, 2015 10:47 AM
