Suspension Input needed ...spacers
Old Feb 28, 2015 | 03:37 PM
cguzz's Avatar
cguzz
Quote:
Originally Posted by cguzz View Post
Any have any tips on measuring for wheel spacers. Not sure about the front bu the rear for sure. I know I'll need extended lug bolts for the rear at least. Trying to get them as flush with the R56 as possible. I have a 2 finger gap between tire/fender. Currently not running any aftermarket lower control arms...but we'll see, going on the alignment tomorrow.
Thanks for any help.
Alignment went great...camber set with room to spare without getting aftermarket control arms or camber plates on front.
I measured and I'm thinking 10mm front and 15mm rear. Right off I'm thinking I need longer hub bolts for the rear, not sure about front yet.
Cosidering Akata on ebay. but in the description on ebay it has "12" as thread type. This being an r56 my lugbolts are 14x1.25. Will these work? I'm thinking 14 is the diameter of the lug bolt thus the holes in the spacers are too small at 12. So maybe not ???
Akatas don't look as nice as the ones from Turner Motorports but wondering if I can get by OK saving $.
Thanks for any knowledgeable input.
Old Feb 28, 2015 | 06:14 PM
BlueThunder's Avatar
BlueThunder
The spacer bolts for R56 vehicles are 14 X1.25 The Spacer bolts for R50, R53 are 12X1.5. Make sure you are selecting hub centric spacers with a raised center bore. Another nice feature is a locating bolt hole that locks the spacer and rotor to the center hub. Spacers for generation 1 and gen 2 are the same . bold diameter and thread pitch are different.
Selecting size depends on wheel offset and tire width. here is a video. Although its for BMW, same applies to Mini Cooper.
http://www.bmpdesign.com/technical/w...rs_for_BMW.php
Old Feb 28, 2015 | 08:01 PM
cguzz's Avatar
cguzz
So if 12 is the bolt hole diameter, Mine is 14? How can that be good?
Old Mar 1, 2015 | 06:24 AM
BlueThunder
I'm nor sure of the other brands but the bolt hole diameters on our Racemax spacers are 14mm. Its the center bore the keeps the wheel to true center.
You may check our web site, the spacers with correct length bolts are not that expensive, and they have the locator bolt system that lock the spacer and rotor to the hub.
Old Mar 2, 2015 | 07:19 AM
NathanMckee's Avatar
NathanMckee
The best looking spacers for the least amount would be the ones from ECStuning. Plus they offer a bunch of widths that fit the 4x100 bolt pattern.
eliseo1981
Jan 28, 2021 02:45 PM
W0TM8
Dec 19, 2019 07:50 AM
boostedhaze
Jan 2, 2018 07:26 PM
iwant2knowwhois
11
Sep 19, 2015 12:18 PM
