R50/53 need some professional help from some experts
Old Feb 25, 2015 | 10:16 PM
Fashizzles84's Avatar
Fashizzles84
my buddy and i are rebuilding a mini r53 w11 motor. it spun a bearing and went through hell and back. he removed most of the components on a day i went to work. tried to off of pure memory thinking it wasnt gonna take too long. getting most of the parts back from the machine shop took weeks. and therefore his goldfish memory didnt stand a chance. i have some left over brackets that i have no idea where they go to. can anyone shed some light on this? thank you in advance. brian..
Old Feb 25, 2015 | 10:20 PM
Fashizzles84
forgot to add the photos lol
here is the photo of the brackets in question.
Attached Thumbnails need some professional help from some experts-img_1911.jpg
Old Feb 26, 2015 | 04:40 AM
JABowders's Avatar
JABowders
Veteran: Army
Here is a start...
See the Parts images for placement ...
Motor on!
Attached Thumbnails need some professional help from some experts-parts.jpg   need some professional help from some experts-front-panel.jpg   need some professional help from some experts-radiator_frame.jpg
Old Feb 26, 2015 | 06:37 PM
David.R53's Avatar
David.R53
The crescent moon shaped piece fits next to the starter to keep crud out of the bell housing of the transmission.
Part #10 here - http://www.realoem.com/bmw/showparts...16&hg=23&fg=15
The top piece in your picture I am a little less sure about - I think it holds the wiring harness in the same area (where the starter bolts to the back of the engine) - it has two closely spaced holes, I think one fits over a locating stud, the other is for one of the starter bolts.
Old Feb 26, 2015 | 08:51 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
Lower left is the wiring harness bracket that is held by the bell housing bolt under the thermostat housing.
Middle 2 is the brackets that go under the bumper bolts to support the front plastic rad support.
Lowr right is cover that goes under the starter around the pass axle where it goes into the trans. held in by 2 10mm bolts
Top middle is the bracket that holds the wiring harness going to the A/C compressor and Crank sensor. The bell housing bolt under the black supercharger inlet tube holds this.
Old Feb 26, 2015 | 10:09 PM
Fashizzles84
Thank you so very much gentlemen. Much appreciated, the only issue now is that I've already installed the engine into the car and pretty much bolted all of it up. Lol I wonder how much work it's gonna take to put these back on correctly..
Old Feb 27, 2015 | 08:10 AM
Helix13mini's Avatar
Helix13mini
I would say that the most important one is the bell housing shield. Don't worry about the harness brackets, and the bumper support brackets can be replaced without messing with the engine. Your goldfish-memory buddy actually did it on purpose: he's improving performance by cutting weight!
n0mis
MINI5280
11
Mar 9, 2016 05:04 PM
Sep 14, 2015 12:48 PM
Sep 10, 2015 10:52 AM
