R50/53 Help SEL and DSC lights= Limp Mode
I am out of ideas I have searched multiple posts to figure this out with no luck. After changing my clutch and getting everything back together I am now going into limp mode once I get above 3k rpm. I got a code reader and am showing P1498 and P2304. I checked my IC boots and the FPR vacuum lines and both looked ok. Any help would be appreciated.
Is your P1498 reading as = Air Leakage After Compressor ?
If it is then I would double check all your gaskets and vacuum lines.
(I throw the P1498 on my MC40 #211 JCW sometimes when I am really hammering it... I can clear it by the 5 start reset technique in lieu of hooking up my laptop to clear the code) I too need to get in there and double check all my post Compressor gaskets and lines.
The difference is I don't go into LIMP MODE, that may be caused solely by the P2304 - Ignition coil B, primary circuit - circuit high ...code... double check your Coil pack install, all the connectors and Ignition Cables (Spark Plug wires).
Also double check your Engine Ground strap.
Best of luck.
Motor on!
Best of luck.
Motor on!
I replaced the SC intake as well as the vacuum hose from the MAP. I saw on one post that the hose from the map was supposed to have 2 blue o-rings on ut. I know the one I installed didn't have any on it. Do you know anything about that?
If i recall right, the o-ring are on the MAP/T-MAP (they look the same but are not, the r53 has 2..the sensor that is...one is a r50 t-map, only map used, the hot side is a r53 specific part, that one uses both temp and preasure)....on the neck of it in the groves.
When my t-map failed, the DSC was lit, and it had drivability issues, but different codes...
Powershift
Aug 16, 2015 05:14 PM
tippin
Aug 5, 2015 08:43 AM
