R50/53 Ordered New Rims I need help.
Old Feb 14, 2015 | 10:52 PM
recon89's Avatar
recon89
I just ordered 17x8 et20 rims with 205/40/17. I have checked just about everywhere im getting frustrated lol. I cant find answers such as the spacers that would be needed. If the tires will rub and if they do how bad, would i have to grind metal down. Would i need additional parts just to have a fitment? Also i ordered vmax coils for it too. In other words would they fit? Do i have to worry about anything? Also i dont know if you guys are familiar with Axm's R53 which runs almost the same specs as mine but his specs are 17x8.5 et20. Im looking for a stance like his...Any help would be awesome.
Old Feb 15, 2015 | 04:03 AM
Kahnfucious's Avatar
Kahnfucious
Why didn't you order the rims in the correct offset to achieve the look you want?
Why wouldn't the coilovers fit? They are generally the same spec as your stock suspension when set at stock height...how low you can go might be impacted by the rim choice.
If you get spacers ... Make sure they are hub centric. You mention Axm...might be worth reaching out to him.
Willtheyfit.com
Old Feb 15, 2015 | 05:37 AM
recon89's Avatar
recon89
Willtheyfit.com
Sorry i know the coils will fit i didnt specify the question correctly. What am asking is would these rims fit correctly or would they rub. Thanks for the website i will check it out.
Old Feb 15, 2015 | 09:17 AM
dannyhavok's Avatar
dannyhavok
Hopefully one of the wheel experts will chime in here, there are a few. However 20 is a pretty aggressive offset, if I had to guess I'd say you might need to adjust camber a bit to make it work. Tire size will be a factor as well. Are you going to stretch tires?
Do you have adjustable lower control arms?
Old Feb 15, 2015 | 02:15 PM
recon89's Avatar
recon89
Yeah, im ordering 205/40/17 so they will be stretched. And no i dont have the adjustable control arms, so these are these are needed? Anything in specific that I have look for while ordering the control arms? Thanks for your help by the way!!
Old Feb 15, 2015 | 04:32 PM
Kahnfucious
Nothing in particular two favorite brands on here are hotchkis and Alta.
when setting your initial length just measure it against the stock - then you must go to an alignment shop. Just so you know each time you adjust the height you are throwing the camber off some. Not sure how people do it - if they align the car every time.
Old Feb 17, 2015 | 09:41 AM
hsautocrosser's Avatar
hsautocrosser
The lower the et number the farther the wheels poke out of the wheel well. Adding spacers moves the wheel even further out.
Looking at his pictures, Axm has extreme negative camber, especially in the rear, to tilt the top of the tire inwards. I second the notion of sending an email or private message to him to ask what all he had to modify.
Old Feb 20, 2015 | 10:48 AM
TheBigChill's Avatar
TheBigChill
For the sake of stance, you're sacrificing so much.
You don't need spacers, as the guy above me said. You need a method to dial in front camber (Front: camber plates, Rear: adjustable camber links), and possibly silly stretched tires so that the wheel & tire can actually clear the inside of the fender flare when the suspension is compressed.
Old Feb 20, 2015 | 11:25 AM
rckrzy1's Avatar
rckrzy1
then your gonna be wearing out those tires fast.
Old Feb 20, 2015 | 11:58 AM
AndyPWR53's Avatar
AndyPWR53
I don't know why people buy wheels not knowing what they need to do to make them fit.
Also, with vmaxx coils and with the camber needed to make those wheels fit the car is going to ride like sh*t and go through tires like crazy. I'm a fan of the stanced look but it just seems like you're sacrificing too much at this point.
Old Feb 21, 2015 | 04:19 PM
TheBigChill
If you're implying that negative camber alone eats tires, you'd be wrong. Toe is the biggest offender of that, and I run 0 toe and -2.5 camber with even tire wear. Additionally, most camber plates allow you to dial in some positive camber, in order to counter the effect of negative camber due to blindly slamming a car to the ground on cheap coilovers. I'm not promoting what OP is doing at all. Rather, I'm saying that with his new wheels and goals in mind, some adjustability will be needed.
Old Feb 24, 2015 | 03:07 PM
recon89's Avatar
recon89
This is what I was looking for. It honestly feels like im driving stock with runflats
Old Feb 24, 2015 | 03:38 PM
Kahnfucious
Does that rub? Looks like it might but I don't know how much give your suspension has... also.. you aren't running the spacers right?
Old Feb 24, 2015 | 03:56 PM
recon89's Avatar
recon89
So far its not rubbing, but thats because I removed the fenders and sanded inner part of them. No spacers. And as of ride height ill get back at you to give you a accurate answer.
schwac2
Jun 14, 2016 04:06 PM
embiggenedmini
Oct 15, 2015 12:36 PM
MasterShaftner
Sep 4, 2015 03:52 PM
Sep 4, 2015 02:34 PM
