R50/53 Disconnecting Sun Visor from Harness
Old Feb 4, 2015 | 01:04 PM
Stinch's Avatar
Stinch
Thought I should ask here before I break something. After removing the two screws holding the visor to the roof, I'm trying to disconnect it from the harness. I don't see any spring clips or the like. Do I simply pull it apart or is there a retainer inside the connector that needs a small screwdriver?
Rich
Old Feb 4, 2015 | 01:58 PM
Stinch's Avatar
Stinch
I figured it out. The rear view mirror uses similar if not the same connector. The sun visor connector is wrapped in cloth and hides a small tab. Working a small screwdriver into the connector on the side with all the small text released the tab and it pulled apart. Sometimes these little things slow me down the most.
USNAE2
16
Jun 17, 2022 07:17 AM
Island maser
General Discussion
Oct 1, 2015 01:09 PM
Giants9595
Sep 29, 2015 10:49 PM
dragonby
Sep 25, 2015 08:10 PM
