Heater is not hot.
Old Jan 30, 2015 | 11:28 PM
sirr6's Avatar
sirr6
Heater is not hot.
I drove my cooper for the first time in about 6 months. It was in the garage with a battery tricker. Well today I was driving it and turned the heat into "hi" but it wasn't getting hot, it was barely even warm. Any ideas on the issue?
Old Jan 31, 2015 | 04:47 AM
Slave to Felines's Avatar
Slave to Felines
Coolant leak. Check the overflow bottle to see if it's empty or low. If so, suspect the thermostat housing.
Old Feb 2, 2015 | 06:19 PM
countryboyshane's Avatar
countryboyshane
Need more information. What was the coolant temperature when you turned on the heater?
Old Feb 3, 2015 | 05:42 PM
mbwicz's Avatar
mbwicz
Your signature shows an 07. If that is the case, there is a good chance that the thermostat needs replacing. Both the water pump and thermostat are plastic and tend to crack over time, which creates a leak. The resevoir also can crack over time. Like stated above, see if your resevoir is low. If it is, top it off with the proper BMW/MINI blue coolant and distilled water.
If it is not low in the resevoir, there is a good chance that the thermostat has malfunctioned and would need to be replaced.
Do you do your own maintenance? There are how-to articles on both the water pump and thermostat replacement.
Have fun,
Mike
Old Feb 17, 2015 | 07:37 AM
+1 most likely low coolant due to a leak.
See here for the thermo housing or the expansion tank.
https://www.northamericanmotoring.co...8-no-heat.html
ahmedalsurmi
Sep 25, 2023 04:49 AM
PsychoRallye
21
Feb 17, 2019 06:08 AM
silence2-38554
Sep 28, 2015 12:19 PM
daonlyillwiz
Sep 24, 2015 02:07 PM
Redhotz
R55 :: Clubman Talk (2008+)
Sep 22, 2015 09:41 PM
