P1637 and P2103
Old Jan 30, 2015 | 10:17 AM
genik's Avatar
genik
P1637 and P2103
Reduced power, showing yellow half engine light on rev meter dash and after an OBD scan, i got P1637 and P2103 error codes. Check engine light on the dash is lit but the misfires and limp mode driving feeling has gone.
What could it be?
Old Jan 30, 2015 | 06:50 PM
AZdsrt's Avatar
AZdsrt
I can't tell you what the problem is, but I looked up the codes -
P1637 Throttle Valve Position Control; Control Deviation (BMW)
P2103 Throttle Actuator Ctrl Motor Circ High
Old Jan 30, 2015 | 09:40 PM
Slave to Felines's Avatar
Slave to Felines
Frozen throttle syndrome?
Old Jan 30, 2015 | 10:06 PM
daddyandmadi's Avatar
daddyandmadi
Is it below freezing there? Sounds like the cold manifold issue. What year?
Old Jan 31, 2015 | 03:44 AM
genik's Avatar
genik
Thanks, but what exactly do they mean though?
What is that?
No its not freezing, its around 15oC.
Aso along with this issue, whenever i leave the car, say for over 8hrs, when i try to start the engine it acts as if there is a HPFP issue. Exactly like
Could they be related?
Old Jan 31, 2015 | 04:46 AM
Slave to Felines
It sounds like they're saying that the throttle plate in the intake is not doing what the ECU is telling it to do.
What is that?
Recently, a number of people in colder climates have been reporting problems where the throttle valve is actually freezing. Water in the air that goes into the intake condenses on the inside of the valve, and then freezes. The throttle plate can no longer move at that point, leading to codes similar to what you are seeing.
But that requires freezing temps, or at least near freezing. 15C is certainly not that! It might be a problem with your throttle valve, then.
Old Jan 31, 2015 | 05:04 AM
genik's Avatar
genik
Ok, but what about the symptoms like in the video posted before, i have exactly the same thing mostly on engine startups! Is there any chance it is not the throttle but the HPFP or vice versa?
Old Jan 31, 2015 | 08:11 AM
genik's Avatar
genik
Did another check and a 3rd code came up... P3091
Old Feb 1, 2015 | 06:56 PM
Spoooolin's Avatar
Spoooolin
Cooper, or Cooper S?
Old Feb 1, 2015 | 09:54 PM
genik's Avatar
genik
Cooper S, why is there some difference?
Old Feb 2, 2015 | 08:38 PM
daddyandmadi
Fuel rail pressure. Throttle actuator a control motor circuit high. Throttle valve position control stuck temporarily.
The fuel rail sounds like hpfp recall. The throttle maybe related the crank case vent
Old Feb 3, 2015 | 11:43 AM
genik's Avatar
genik
I dont understand what you are saying here! Sorry
Old Feb 3, 2015 | 01:36 PM
daddyandmadi
sorry for the cryptic response. I was on my IPhone.
The codes are as follows:
P1637 - Throttle Actuator A Control Motor Circuit High
P2103 - Throttle Valve Position Control stuck Temporarily
P3091 - Fuel Rail Pressure
I was speculate that the Throttle control unit issue. However, all three maybe related to the crankcase ventilation. If you are troubleshooting yourself, try to clean/check/change that first.
Old Feb 3, 2015 | 08:55 PM
genik's Avatar
genik
1. Could all of these codes (P1637, P2103, P3091) be related with the HPFP, or are there two type of issues im facing with here? One of the Throttle and another one of the HPFP
2. What exactly is the crankcase ventilation, issue? Can it be checked and how?
3. My main concern is, how should the technician begin to diagnose correctly, because most just have the tendency to start changing stuff until the problem ends. But this method can mean a lot of wasted money!
Old Feb 4, 2015 | 06:28 AM
daddyandmadi
I believe the crankcase vent would be the logical place to start. Looks like a $25 part, so that's the good news.
I thought just my MINI dealer randomly changed parts. Maybe it's part of their training plan......
http://parts.miniofkennesaw.com/show...category=19711
Old Feb 4, 2015 | 11:11 AM
genik's Avatar
genik
Thanx but, what exactly is the crank vent case valve for? And why do you believe that its the first things i should check?
Old Feb 4, 2015 | 12:56 PM
daddyandmadi
The crank case regulates the pressure and the fuel mix. Here's an article that explains how to do a quick check
http://www.agcoauto.com/content/news/p2_articleid/197
Also, I would check your ECU and see if its in ok shape. Its like a fuse box on the left side inside the engine. Just check to make sure no rust, connections are tight etc. I hope its not that as that gets expensive.
I do have a repair manual at home. If you need a page or two scanned and emailed to you, let me know
All the best
Old Feb 7, 2015 | 06:08 AM
genik's Avatar
genik
All the best
Many thanks, let me ask though, suppose its the crankcase valve, would the symptom come and go or would it be a continuous issue? Because with my little knowledge, i suppose that if the issue comes and goes maybe its a short circuit or electrical thing and not a mechanical problem... what do you think?
If its a bad crank case valve, then i would put that to be a mechanical problem, dont you think?
Old Feb 18, 2015 | 12:39 PM
shipjumper's Avatar
shipjumper
Mine was just in yesterday for the third time on this. The first time was because the throttle stuck. Towed in, and they cleaned out the intake manifold (09 justa clubbie). The second time they said the moisture was from the valve cover not venting properly and replaced my valve cover.
Today was because there is some random residue in the throttle making it stick.
ugh. up here in northern VT it has been -20 to around 0 for about a week now. this has been coming and going. I have been told to flog my car more to clear it out. "italian tune up" if you will.
I just passed 96K and out of my CPO for a month when it happened. This never happened last year with the same temps, etc.
I want to take this car to 200K, I hope it wont keep happening.
Old Feb 18, 2015 | 02:22 PM
genik's Avatar
genik
shipjumper do you remember what errors came up for all this that you describe?
Old Feb 20, 2015 | 10:12 AM
shipjumper's Avatar
shipjumper
I don't remember the codes, but when i pulled them it was "throttle plate permanently stuck" is what the code read on Torque on my phone. The dealership confirmed it. Repair 1 was the cleaning of the intake manifold and throttle plate assy. Repair two was the valve cover, suspecting of being filled with carbon and moisture. I just got it back and they suggested driving it harder sometimes, as 45min of my commute is spent at 2800rpm and 70mph. No load, im guessing is what causes it. I also run 0% ethanol (pure gas), does the E-10 gas have more cleaning agents?
Considering a Diesel MB, BMW, VW or a GM Cruze diesel. I have very few requirements, comfort, MPG's (40+), bluetooth and Tq. In that order.
Old Mar 6, 2015 | 02:46 PM
genik's Avatar
genik
I just replaced the HighPressureFuelPump but the Throttle valve errors (1637, 1638) are still there. If its the Throttle valve, maybe i need to fix it, maybe clean it someway. has anyone got an idea on how to do this?
Old Mar 21, 2015 | 11:51 AM
genik's Avatar
genik
Could the Throttle Valve errors (1637 & 1638) im having, be due to carbon build up in the valves or the intake manifold?
Old Mar 21, 2015 | 01:02 PM
Slave to Felines
Dunno. Have you checked the inside of the throttle valve? If it's gummed up, I could see that causing errors like you're mentioning.
Old Mar 21, 2015 | 01:18 PM
genik's Avatar
genik
How easy is it to have a look inside the throttle valve?
