Stud Conversion?
Old Jan 5, 2015 | 04:42 PM
Catch_Me's Avatar
Catch_Me
Stud Conversion?
Hey just ordered some r90 wheels and H&R 5mm wheel spacers for the r53 checkmate. I was just wondering what studs would look ok with this setup without sticking out way to far and looking wrong. I was thinking 50mm H&R studs. Thanks
Old Jan 12, 2015 | 07:54 PM
afadeev's Avatar
afadeev
Why do you need studs?
With only 5mm spacers, you should still be able to get full 4 turns of the OEM lug bolts in the wheel hub. If not, just order another set of longer lug bolts (cheaper than studs).
a
P.S.: 2 vehicle with bolts, 1 with studs. Already butchered threads on 2 studs when I got lazy sliding wheels on them. Fixed with SnapOn thread chase kit, but that's another $130 ;-(
Old Jan 15, 2015 | 04:56 PM
Btwyx's Avatar
Btwyx
Originally Posted by afadeev
Why do you need studs? With only 5mm spacers, you should still be able to get full 4 turns of the OEM lug bolts in the wheel hub.(
I would not want to be running on only 4 turns. For reference the SCCA tech standard is 7 turns, I think that's a bit skimpy.
Old Jan 19, 2015 | 02:19 PM
Alex@tirerack's Avatar
Alex@tirerack
This is also TireRack's standard when we select the bolt length for our wheels.
NYMADMINI
Dec 14, 2016 02:33 PM
vetsvette
Oct 11, 2015 06:05 PM
Oct 1, 2015 12:13 PM
Sep 29, 2015 12:11 PM
