New Rota's Going On Soon. Couple of Questions.
Old Jan 4, 2015 | 08:15 AM
14R55S's Avatar
14R55S
I really like the old school Rota look so I will be purchasing a set of RB's from Aspec. My Clubman is new with only 1,700 miles on it. I can't justify new tires at this time so these will be mounted on stock 195/55/16 run flats. Current wheels are Mini Rib Spoke which are 6.5" wide. The Rota's are 7" wide. Will these fit my tires? Any issues with TPMS? Should be a straight forward switch out right? These are the wheels:
Old Jan 4, 2015 | 09:30 AM
ashchuckton's Avatar
ashchuckton
Very nice wheel, one of my favorites. Your tires will fit without problems & I'm sure the TPMS sensor will too. Those are going to look great on your clubman.
Old Jan 4, 2015 | 11:49 AM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
I'm not sure if those in 16inch will fit over the brakes, I know we put the 17inch rotas on and they were pretty close.
Old Jan 4, 2015 | 12:17 PM
14R55S's Avatar
14R55S
Offset on the Rota's is 40mm. Rib Spoke is 48mm. Does that help?
Old Jan 4, 2015 | 12:47 PM
ashchuckton
To be sure contact the seller of those wheels they should know.
Old Jan 4, 2015 | 12:54 PM
14R55S's Avatar
14R55S
I certainly will. Thank you. I can always use spacers I suppose.
Old Jan 4, 2015 | 03:55 PM
zamfield's Avatar
zamfield
Just put the Hyperblack's on my 05... Love 'em!
(These are 17's with 205/40/17)
Coilovers on Friday!
Got them from MachV (fastmini.net) for $640.
Fit is perfect and no rubbing at all.
Old Jan 4, 2015 | 05:36 PM
14R55S's Avatar
14R55S
Found this thread from way back. Looks like they will fit with no problem.
https://www.northamericanmotoring.co...rota-rb-s.html
Old Jan 4, 2015 | 08:44 PM
MiniKar's Avatar
MiniKar
You will be much happier if you buy new non-runflat tires now.
The ride and noise difference is unbelieveable
Post the runflats for sale. Once they get a wear pattern you can't give them away.
Old Jan 4, 2015 | 09:34 PM
minihune's Avatar
minihune
OVERDRIVE - Racing Champion
Your new wheels should fit, TPMS can be transferred to the new wheels if done carefully.
New non runflat tires do not have to be expensive considering the cost of mounting and balancing runflats.
see
http://www.tirerack.com/tires/survey...=true&filter=y
About $90 or less per tire in Ultra High Performance All Season, more choices in 205/50-16 and 205/55-16.
You can either sell the runflats with the OEM wheels as a set and skip the dismounting of the tires or part out the wheels from the tires unless you are keeping the wheels for winter use.
donniedarko
Oct 21, 2015 01:15 PM
LAcooper
Sep 22, 2015 10:03 PM
atlantaorange
Sep 16, 2015 12:43 PM
MiniUnz
Sep 14, 2015 11:11 AM
Mb460
Sep 14, 2015 05:50 AM
