A little bit of help..
Old Dec 18, 2014 | 03:26 PM
Camaroboy14's Avatar
Camaroboy14
I have a 2009 mini cooper nonS, and was wondering where I can find a particular style of wheel for a reasonable price. .
http://m.ebay.com/itm/141444661744?nav=SEARCH
I like these BMW style wheels that kind of have that concave look to them .. idk if it's called that where the middle sinks in a little. . Thanks in advance
Old Dec 18, 2014 | 04:15 PM
minihune's Avatar
minihune
OVERDRIVE - Racing Champion
Go to tirerack.com and click on upgrade garage, put in 2009 MINI Cooper
You will get a very long list of possible wheels that fit in various price ranges-
see
http://www.tirerack.com/wheels/resul...All&sort=Brand
On a budget in black finish this one seems OK,
Sparco Pro Corsa, 22.5 lbs each
only 14 spoke not 16 with some concave to the hub. 17x7.5" et 42 $148 each
will work with 205/45-17 or 215/45-17 tires
See also
Breyton Race GTS-R Mini Matte Grey Finish 14 spoke design
17x7" et40 $209 each closeout special, 17 lbs
Enkei M52 Black painted finish (also hyperblack or matte grey) 10 spoke design
15x6.5" et38 $113, 15.6 lbs
17x7.5" et42 $143, 20.5 lbs
Enkei Racing PF01 Black painted finish 10 spoke design
17x7" et38 $266 each, 15.5 lbs (very light for 17" wheel)
MSW Type 25 Matte Grey Finish 14 spoke design
16x7" et 37 $99 each, 18.8 lbs
Anzio Vision Matte Graphite Silver finish 14 spoke design
15x5.5" et45 $105 each, 15.8 lbs
Old Dec 18, 2014 | 05:03 PM
Camaroboy14
see
See also
Thank you for the links the sparco ones look about right! !
Old Dec 18, 2014 | 05:12 PM
minihune's Avatar
minihune
I think the sparco wheels are fine for the price. At 22.5 lbs each they are very close to OEM MINI wheels which are somewhat heavy. Using a base Cooper you don't have tons of extra power but for street use these should work fine.
More important are which tires you want to use.
If you want better street comfort and slightly less wheel gap and you plan to keep your stock suspension then look for 215/45-17 tires which give you a larger selection of possible tires. Tirerack.com search will show many examples or you can contact Alex@tirerack.com for more info. If you do order Sparco wheels from terrace.com you can also get them with tires already mounted and balanced.
Since you are in Germany, did you want to use the tires year round in the cold and snow or just in the warmer months and use winter wheels/tires for snow? What is your budget for tires? What are your priorities? Comfort, handling, treadwear, price, etc?
Old Dec 19, 2014 | 08:24 AM
Alex@tirerack's Avatar
Alex@tirerack
This look is due to wider wheels and different offset requirements. These specs, unfortunately wouldn't work. The pictured wheel looks like the rear M3 fitment.
Old Dec 20, 2014 | 06:00 PM
minihune's Avatar
minihune
Alex,
I think the OP was interested in the appearance of those wheels and used that link as an example only, otherwise as you stated the bolt size and width were not for the MINI.
That concave type hub spoke design lends itself more to a wide rim, in fact some wheels come with several options for how deep a concave face you can order depending on offsets and wheel width.
RobbyD
Jan 29, 2019 01:22 PM
pglgp1292
Aug 9, 2017 12:45 PM
bctf1
Jan 2, 2016 04:02 PM
jeri534
Nov 6, 2015 01:40 PM
jennster
Sep 28, 2015 06:19 PM
