R60 Battery Charge Level Low??
Old Dec 15, 2014 | 10:33 PM
minicountry's Avatar
minicountry
Does this mean I need a new battery?? I hooked up with battery tender a week ago and today the warning sign reappear.....
Does battery covered under warranty? Mine is 2011 with 72k km still under warranty.
If I replaced the battery myself do I need to get the battery registered/reset?
Please help
Old Dec 16, 2014 | 07:39 AM
barchstein's Avatar
barchstein
you might want to check if the battery is actually being charged...
i had issue a couple of months ago. the crankshaft damper belt broke and then when they fixed it. they noticed that the battery wasn't charging anymore...
Old Dec 16, 2014 | 07:48 AM
minicountry
so what is the solution? replaced battery? does it cover under warranty?
Old Dec 16, 2014 | 08:03 AM
TrueEddie's Avatar
TrueEddie
In my last car (335i) I had an "Automatic" OBD-II sensor plugged in that over time caused the battery to drain to the level where it needed to be replaced. Do you have something plugged into your OBD-II port? If so that could be what is causing your battery to die.
Old Dec 16, 2014 | 08:07 AM
minicountry
What about an iPhone on the USB audio port? Does it cause power drain too? I thought it will stop charging as soon as you lock the car
Old Dec 16, 2014 | 08:11 AM
TrueEddie's Avatar
TrueEddie
I think I've seen a number of people on these forums leave devices plugged into the USB ports with no issue. As far as my 335i, even with the car off it still caused drain. With the BMW it would enter "Maintenance mode" when something was plugged in to the OBD-II port. So the car would never fully go to sleep.
Old Dec 16, 2014 | 09:22 PM
kingalien's Avatar
kingalien
I’ve had mine for 3.5 years. I do not leave the alarm on overnight (garaged) and I have an iPod Nano attached all the time to the USB audio port.
I recently came back from a 3 week holiday and noticed a labored start and the same warning message appeared, “Battery Charge Level Low.” I drove it for a couple of days and no issue until the same message appeared again. I took it into the dealer and they did their checks. No faults relating to low voltage was found. An energy diagnosis was done and it came back with a “Battery Aged Fault Code.” A “Midtronic test on battery” was done and failed. Dealer replaced battery under warranty.
Old Dec 16, 2014 | 09:32 PM
minicountry
Good to know this I will get the battery tested by the dealer when I get my engine mount replaced end of this month. Hopefully they will replaced the battery for me too under warranty
stevepsd
35
Dec 6, 2022 03:22 PM
eliseo1981
Jan 28, 2021 02:45 PM
Aug 21, 2015 11:25 AM
Getrieben
Aug 15, 2015 09:09 PM
Emnotek
Aug 13, 2015 05:47 PM
