R59 Passenger window one touch up?
Old Dec 11, 2014 | 01:49 AM
tmehanna's Avatar
tmehanna
Just took delivery a day ago and noticed that while the driver side window can go up and down with one touch of the switch, the passenger side only goes down with one touch, I have to keep holding the button in order for it to go all the way up. Does it have to be coded for one touch closing?
Old Dec 11, 2014 | 04:55 AM
spiney's Avatar
spiney
One touch up on the driver's side? You lucky so-and-so. Most of the Roadsters I've seen (mine included) don't have any one-touch up at all, unless you have had it coded in. I had that done once, but then had a computer swap under warranty and lost it
I would expect you can have this done by someone. Helix did mine at the Dragon, but I know there are others. I've even seen people who will do it remotely, where you get the cable, either from them or get your own, and they connect to your PC remotely over the Internet and code it in your own garage.
Old Dec 11, 2014 | 08:58 PM
TG.'s Avatar
TG.
Does anyone here familiar with BMWhat? and wether or not the one touch up could be accomplished with it?
Old Dec 12, 2014 | 03:22 AM
scubbysnacks's Avatar
scubbysnacks
http://www.ivini-apps.com/coding.html
Here's a link to their site which list current coding possibilities. I just shot them an email about coding removal of GPS disclaimer on startup and park lights as driving lights. I'll let you know their response you could email them about the window coding.
Old Dec 12, 2014 | 04:19 AM
TG.'s Avatar
TG.
I wouldn't mind (it's one less email for them )
I look through the list and didn't see anything about the one touch up (or down)...
I noticed that many of those codes are function you can change with the trip computer. Perhaps that's where the limitation is (?)
Old Dec 12, 2014 | 05:04 AM
tmehanna's Avatar
tmehanna
GM5: Window tip function driver door 1/2 active
not active
BMWhat: Driver door window fully opens by tapping the window switch.
GM5: Window tip function driver door 2/2 active
not active
BMWhat: Driver door window fully closes by tapping the window switch.
GM5: Window tip function passenger door 1/2 active
not active
BMWhat: Passenger door window fully opens by tapping the window switch.
GM5: Window tip function passenger door 2/2 active
not active
BMWhat: Passenger door window fully closes by tapping the window switch.
Old Dec 12, 2014 | 05:22 AM
TG.'s Avatar
TG.
Weird I missed it when I did a find "window" search.
thx!
Old Dec 12, 2014 | 05:27 AM
TG.'s Avatar
TG.
Ah, I was looking under the MINI (R56) tab. Not the E46.
I don't know what it means in terms of R59...
Old Dec 12, 2014 | 05:43 AM
spiney's Avatar
spiney
As I said above, you definitely CAN code it in for the R59, using NCSExpert at least. Whether this BMWhat? app allows that access I'm not sure, but the setting is there in the car. I'm seriously considering getting a cable and having a go. The only wrinkle in my case is that I don't have any Windows stuff in the house, but I think it should run from a Windows virtual machine on my Mac.
Old Dec 12, 2014 | 06:08 AM
cerenkov's Avatar
cerenkov
I bootcamp to Windows 7 64 bit on my Mac, works just fine. I also have VMWare Fusion installed but have not tried doing it through that.
That only tricky part is buying the right cable (it can be a crap shoot) then installing and getting everything to communicate correctly. Once that is done the actual coding only takes minutes.
We should setup a cable sharing program.
Old Dec 12, 2014 | 07:23 AM
tmehanna's Avatar
tmehanna
I do have the cable but it's just too much trouble having to learn how to code for just this small job. It's easier to go to the dealer and ask them to do it for me, though bmwhat is an intriguing option.
Old Dec 12, 2014 | 04:38 PM
TG.'s Avatar
TG.
In a way that's what I'm thinking . . .
On the other hand "I" personally plan to keep the car for a long time (perhaps 10 years at least), soooo I wouldn't mind diving into NCSExpert. But it would be a big help for a newbie like me (and I'm use to computers and fussing with them so that's not the issue) if someone could sum up the actual hardware I would need specifically, and the latest version to date of the software or softwares I would need to get started... I could even get a cheap, inexpensive computer or tablet I could setup so as I change computers over time I could keep this dedicated computer for the MINI programming, monitoring only...
Having said all this I have no idea what I'd be getting into which has me going back to the vary beginning of keeping it simple
Old Dec 12, 2014 | 04:48 PM
tmehanna's Avatar
tmehanna
From what I have learned you could get a fairly inexpensive bluetooth obd scanner, connect it to your android phone and use bmwhat to code. Sounds too good to be true. I am planning to borrow a friend's scanner next week and will let you know if I will have any luck coding the window. The only problem I can see at this point is the R59 is not explicitly supported by bmwhat but ecu should be shared with other supported models. Bmwhat lets you test if communication can be established with the ecu.
Old Dec 12, 2014 | 05:29 PM
TG.'s Avatar
TG.
That would great!
I think it is more likely that it will connect fine t an R59. What is more unknown is what features/codes can actually be changed.
Old Dec 13, 2014 | 02:42 AM
scubbysnacks
I downloaded their lite app and connected to my nexus 7 using my Bluetooth dongle that I use for Torque and it seems to work fine but coding is not activated with their lite version. Also when you connect and go into coding its pretty limited, hopefully by emailing them about additional coding they can add requested coding, have still not heard back from them but it is the weekend so I'll wait and see.
I've read on the net that the cable for coding with NCSEpert is $100 but this app is around $60( if you use torque with bluetooth no extra hardware required)so if they can add the coding you require its a win in for you and the app developer and on here all we know is winning
Old Dec 13, 2014 | 05:07 AM
jkapinos's Avatar
jkapinos
Yes BMWhat is the way to go. A WiFi adapter and an iPhone is all you need. I only have the lite version as well, so have not had time to try it.
Old Dec 13, 2014 | 05:50 AM
TG.'s Avatar
TG.
It cannot be the way to go until someone as actually tried it
Old Dec 13, 2014 | 05:58 AM
jkapinos's Avatar
jkapinos
Even if it doesn't work, you can still read mini specific codes and have not spent a lot of money.
Old Dec 13, 2014 | 06:46 AM
tmehanna's Avatar
tmehanna
Would you be able to install an apk?
Old Dec 13, 2014 | 07:08 AM
cerenkov's Avatar
cerenkov
Is one touch open/close on the windows even an option supported by the app? I don't see it listed (am I blind?):
Old Dec 13, 2014 | 09:13 AM
TG.'s Avatar
TG.
That's what I was talking about before. it's listed under E46 but not under MINI (R56). It's all the same BMW software but it doesn't give me a lot of confidence since they show so many variation between models. It's possible the list isn't up to date... that's why I don't know what to make of it...
Old Dec 13, 2014 | 10:34 AM
rkw's Avatar
rkw
Why not NCS Expert?
I have the following impression, and somebody please correct me if I'm wrong. NCS Expert software is from BMW and includes all options available in the firmware. BMWhat is a consumer friendly software product that implements some but not all of the functions in NCS Expert.
Old Dec 13, 2014 | 10:49 AM
jkapinos's Avatar
jkapinos
I'm talking about cost and trial and error. BMWhat software cost $49.99 and a Wiki WiFi. It's very little cost to try and it's where the auto industry is going for people that mod. If mini people are buying the software then they will write more code if not then they won't.
Old Dec 14, 2014 | 10:31 AM
tmehanna's Avatar
tmehanna
Sad to report that BMWhat was unable to communicate with any of my '15 R59 JCW ECUs
Old Dec 14, 2014 | 11:53 AM
TG.'s Avatar
TG.
That is disappointing
Back to square one.
