Issue with high pressure pump and oil pump solenoid leaking
Old Dec 4, 2014 | 10:06 AM
michmike's Avatar
michmike
hi everyone,
i am new to the forum and i am posting elsewhere as well. I just took my "2011 Mini Countryman S" with 60k miles to the dealer after it started running crappily and i feel like these problems should be pervasive and could help others.
possibly we can even start a recall campaign as the solenoid issue could be a result of poor craftsmanship.
The car was throwing a bunch of error codes on the OBC like
Multiple misfire detected
Cylinder 4 misfire
P0300, p0302 p0304
P0087 fuel rail system pressure too low
All those problems were a result of my high pressure pump faulting. That could be a result of wear and tear. I also found out that previous mini models had issues with the pump faulting and there might have been some recalls as well, but my model has a newer pump. Guess what, that starts to fail now too :(
When the dealer opened the car, they also found that my oil pump solenoid is leaking oil into the wiring harness (the electrical system that plugs all over the engine). Damaging the wiring harness could short the computer and overall moisture and oil on that harness is bad.
I think the latter problem is a result of poor craftsmanship. the dealer wants 600 usd to replace the solenoid, but the wiring harness replacement is twice that amount.
have others gotten similar problems on their minis?
good luck everyone and drive safe.
mike
Old Dec 4, 2014 | 10:57 AM
Slave to Felines's Avatar
Slave to Felines
Two oil pump solenoids have leaked on my car. Both were replaced under warranty, the most recent one just a month ago. Evidently the fix now is to replace the wiring harness with one that is epoxy filled, so that when the solenoid leaks again the oil doesn't make its way to the ECU.
Talk about a half-***ed fix...
Old Dec 4, 2014 | 02:55 PM
michmike's Avatar
michmike
I hear you. good for you that this was under warranty.
Old Dec 5, 2014 | 09:56 AM
u238's Avatar
u238
I can confirm that the 2011 HPFP is a POS just like all the others. I also have the solenoid leak but I currently can't get any warranty work done due to being overseas. You're still under warranty and they want to charge you for the replacement?
Old Dec 5, 2014 | 01:56 PM
michmike's Avatar
michmike
thanks u238. I am not under warranty anymore since my car has over 60k miles. :(
Old Dec 5, 2014 | 03:52 PM
u238's Avatar
u238
I haven't done the replacement myself, but it appears to be a seriously easy job if you are at all mechanically inclined. The pump is right at the top of the head. The dealer did it in under one hour for me.
The solenoid is much more involved. You have to drop the oil pan. :(
Old Dec 5, 2014 | 05:55 PM
wzabrouski's Avatar
wzabrouski
My car was dropped off today to have the HPFP replaced for the second time this year....
Old Dec 9, 2014 | 06:02 PM
wzabrouski's Avatar
wzabrouski
Had both HPFP and LPFP replaced.
Old Dec 10, 2014 | 03:00 AM
Systemlord's Avatar
Systemlord
That how Mini improved the design of a leaking oil pump solenoid, why don't they fix it to where it doesn't leak? I just don't get it.
Etrain
16
Aug 5, 2024 04:37 AM
TREX
Nov 2, 2019 07:31 PM
Colt45Magnus
Jul 14, 2019 06:18 PM
wind715
Aug 11, 2015 07:56 AM
Ambient Thermal Management
Aug 7, 2015 12:27 PM
