Suspension Koni FSD and NM Springs
Old Nov 30, 2014 | 05:22 PM
vicj's Avatar
vicj
While technically, I know your "not supposed to do it", I've read threads on other forums about people mixing Koni FSD shocks with NM springs. Obviously, shock life would be slightly reduced on the lower springs, but just wondering if anyone here had used this combination, and what their thoughts are about it.
Old Nov 30, 2014 | 07:43 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
It won't work. The shaft will have too much travel and damage the valve at the bottom of the shock and ruin the shocks. We've seen this before and so has Koni, so they know what it looks like and will not warranty it. If you want to lower with the NM springs go with the Koni Yellows.
Old Nov 30, 2014 | 07:49 PM
Fly'n Brick's Avatar
Fly'n Brick
...and since Way was kind enough to respond in such a timely manner and offer sound advice, give him a chance to fill your order. It's the right thing to do.
Old Nov 30, 2014 | 07:51 PM
WayMotorWorks
Vendor
Thank you for the kind response. It's hard to compete around here with the vendors that pay someone to post links to their parts within minutes of the original post being made.
Old Dec 1, 2014 | 07:31 AM
vicj's Avatar
vicj
I already have the NM springs installed with the factory shocks. Trying to get rid of that slight vibration because of the axle angle. So, in your opinion Way, wouldI be better off adding the Koni yellows to the NM, or picking up a set of St Coilovers, which I could raise slightly? Which would give me the most forgiving street drive?
Old Dec 3, 2014 | 02:36 PM
Dr. Spade's Avatar
Dr. Spade
Yellows set to soft. Much better shocks
Old Dec 4, 2014 | 04:13 AM
vicj's Avatar
vicj
oh?
Do you know who makes the KWshocks? What I've read from other board members is that the KW is a little soft for their taste, especially on the track. That may be exactly what I'm looking for....as my car will never sniff a track, but sure does find some bad roads....
Old Dec 13, 2014 | 10:42 AM
daddyandmadi's Avatar
daddyandmadi
Way, you could pay me to post links to your parts. I'll work for parts. LOL
Steffen.Johnson
42
Jan 25, 2023 02:47 PM
CooperSharp
Oct 12, 2015 09:21 AM
Suspension Products
Oct 1, 2015 11:53 AM
Suspension Products
Oct 1, 2015 11:14 AM
nshannon29
Sep 30, 2015 05:21 PM
