R57 Part not available? Suggestions Please
Old Nov 24, 2014 | 02:18 PM
JBinABQ's Avatar
JBinABQ
We have a 2010 convertible that we love but are amazed that a simple part we need is not available, at least directly. We went to install a Mini Wind Deflector and noticed that the black, plastic insert that the deflector attaches to, was missing on the rear, drivers side trim panel. I was able to find the part (through various dealers) for the 2008 and earlier model, its called a wind deflector support. Was told it is not available for the 2010 and later - you would have to buy the entire rear, interior trim panel. $10 part just went to $180 part. After emailing a couple wrecking yards, it's clear I can't explain what I need or they are just not interested in such a small transaction. I may buy the 08 insert just to see if I can make it work but am wondering if any of you all have any other suggestions? Thanks to all!
Old Feb 10, 2015 | 06:25 PM
americo11's Avatar
americo11
There are always People on this site in the marketplace section who are parting out various models. I would recommend posting a wanted ad for the part and if possible a picture. Or purchasing the interior panel needed which would be much cheaper going through someone parting out an interior.
Good luck
Old Mar 19, 2015 | 06:19 PM
wmsue's Avatar
wmsue
If you can take a few photos of the piece you need and get dimensions, I can try and 3D print one for you. I have students who are learning to create and print objects. No guarantees, but we can try.
Let me know
Bill
Old Mar 20, 2015 | 06:48 AM
That time that holds it is part of the panel on the R57 . #5 is the screw.
http://www.realoem.com/bmw/diagrams/e/f/267.png
The Gen 1 r52 convertible wind deflector fits in the R57 and vice-versa. So the hole is th same size, But the outer dimensions might be different , worth a shot to try the R52 one.
R57
R52
Look to be the same oval, but the outside shape is a bit different.
R52
#2 black http://www.ecstuning.com/Search/SiteSearch/51436960173/
#3 spacer http://www.ecstuning.com/Search/SiteSearch/51437131111/
maniacalmorgan
Aug 21, 2015 03:03 AM
maniacalmorgan
Aug 20, 2015 01:08 PM
Dsinkster
Aug 17, 2015 03:24 PM
elightbo
Aug 17, 2015 01:50 PM
