2012 MCS 17x7.5 offset 38?
Old Nov 19, 2014 | 08:14 AM
Mumuti's Avatar
Mumuti
hi people!
i need to know if this wheels size fit in my mini 2012 S ? if it yes this size can use a 205 45 tires?
Best Regards
Old Nov 19, 2014 | 12:05 PM
minihune's Avatar
minihune
OVERDRIVE - Racing Champion
Originally Posted by Mumuti
hi people!
Best Regards
Which suspension do you have? Stock MINI or aftermarket and lowered?
If you have stock suspension then those wheels will fit with either 205/45-17 or 215/45-17 tires.
Compared to stock 17x7" MINI wheels with 48 offset those 17x7.5 38 offset wheels will have the inner rim 3.6 mm further from the inner suspension strut and poke out 16.4 mm.
Once suspension is lowered there will be much less clearance for a wider than stock wheel and taller tires, so 205/45-17 is a better tire size for a lowered MINI using those wide wheels.
You might check to see what the wheel weight is, likely it is very heavy being wider than stock. If you only do street driving then you should be OK. Note that heavy wheels increase braking distance and slow acceleration.
Old Nov 19, 2014 | 12:37 PM
Mumuti's Avatar
Mumuti
Thanks Minihune!
i have stock suspension and i think the new wheels are lighter than the stock, do you know the weight of stock wheels?
i have this
Old Nov 19, 2014 | 06:15 PM
minihune's Avatar
minihune
Your wheels are R121 Conical Spoke in Black, weight is 22 lbs each.
http://minicooper.wikia.com/wiki/OEM_Wheels_and_Tires
The lightest OEM 17x7" is about 20 lbs.
Which wheel were you thinking of?
Which tire?
Old Nov 20, 2014 | 09:30 AM
Mumuti's Avatar
Mumuti
Which tire?
this wheels with 205 45
View this post on Instagram
Old Nov 20, 2014 | 05:07 PM
minihune's Avatar
minihune
OK, just make sure that you get 4x100 bolt pattern and ask about a set of Centering rings to fit the MINI 56.1mm hub bore. A set of rings can come with the wheels or you may be charged extra.
Old Nov 20, 2014 | 07:13 PM
Mumuti's Avatar
Mumuti
Oh ****! This wheels are 73.1
If this wheels not come with these ring? Whats sizes of rings i need??
Thanks so much men
Old Nov 20, 2014 | 07:35 PM
Joeygonz's Avatar
Joeygonz
You're going to need a 56.1 to 73.1. They are commonly available on eBay for $5 shipped!
Those wheels are real nice! You might want to also consider….
http://www.ebay.com/itm/5zigen-zr-520-wheels-Bronze-17x7-5-42-4x100-Rare-wheels-Civic-Integra-Fit-/221594341679?pt=Motors_Car_Truck_Wheels&hash=item33980d512f&vxp=mtr
It's a dedicated 4x100 4-lug wheel versus a universal fitment. Feels like it was meant to be. Check out google images on a mini cooper.
Old Nov 20, 2014 | 07:39 PM
Joeygonz's Avatar
Joeygonz
hub rings…
http://www.ebay.com/itm/350815090966...84.m1436.l2649
Old Nov 30, 2014 | 08:13 AM
Zillon's Avatar
Zillon
Agreed with Joeygonz on here - stay away from universal bolt pattern wheels.
Kimolaoha
Jul 5, 2023 01:04 PM
R60abq
R60/R61 Stock Problems/Issues
Jun 6, 2017 05:15 PM
FrostyFox
Oct 28, 2015 02:06 PM
TOMSR53
Aug 26, 2015 10:18 AM
Colt45Magnus
Aug 13, 2015 11:18 AM
