R50/53 Grinding rotational noise when driving on right side :(
So i've been getting this sound mildly a few weeks ago... and as of last night it got a lot worse. I had taken off the wheel a few days ago to see if the sound was coming from grinding on the rotor dust shield, or the pads were wearing down at an odd angle. Everything was fine... so today since I had some light i figured i would take the wheel off again and look around. The only thing I can see is maybe this? Should there be a gap here at the end of the drive shaft? :/
That's the axle I just used to replace my driver side on Monday.
I've gone through a bunch of axles and this one seems to run great so far. Be careful where you get them from...
My mechanic had to shave a few thousandths of an inch off the driver side axle because it wouldn't fit right. Had it fall out on me.
If you do it yourself, make sure you have the axle in fully. The mechanic mentioned a click. I'm not sure. Just double check for leaks and such. Don't let it fall out on you like I did... lol
Here's a POV video of how to do it:
This guy has great videos. Even cool to watch.
R50/53 2002 R53 Creaking/Clacking
maestro39
Oct 27, 2015 02:38 PM
cm.d
Aug 19, 2015 08:51 AM
