Rubber on coil bolts coming off
Old Nov 3, 2014 | 07:15 AM
traildog's Avatar
traildog
I see what appears to be rubber washers squishing out around the bolts on the coil.
I found one of them torn off yesterday.
Is that something I should replace right away?
Old Nov 3, 2014 | 07:53 AM
ZippyNH's Avatar
ZippyNH
Naw...if you want too you can...
Just don't over tq it when you reinstall, or you will crack the valve cover...you are taliking about the ignition coil right?
Think the "washers" are just orings....they ARE important to prevent vibration, etc...but a few days should be fine. Some aftermarket coils use one rather than two of them to fit snuggly...
Old Nov 3, 2014 | 07:56 AM
traildog's Avatar
traildog
Yep, the igntion coil. The bolts were not torqued to the proper speck when I bought the car, so, I tightented them the the spec in the shop manual.
I'm betting I'm the one who made them squish.......
Old Nov 3, 2014 | 08:05 AM
traildog's Avatar
traildog
Just found them on ECS tuning.
Old Nov 3, 2014 | 08:10 AM
Just going to mention that: Part # 12137510737
http://www.ecstuning.com/Search/SiteSearch/12137510737/
#9 One per coil pack bolt. They come on the bolts also.
Ryephile
Suspension
113
Feb 9, 2020 03:43 PM
W0TM8
Dec 19, 2019 07:50 AM
yukinoinu
14
Jul 2, 2016 07:27 AM
ShadyCoop
Aug 24, 2015 06:05 AM
minipopkart
Aug 13, 2015 05:22 AM
