clay bars
Old Oct 30, 2014 | 11:51 PM
angrymini's Avatar
angrymini
clay bars
I have heard a few things about using clay bars and a few other products to keep that new car look. Any input on this would be greatly appreciated. I dont want to use anything that could end up damaging my car.
Old Oct 31, 2014 | 04:01 AM
ShipM8's Avatar
ShipM8
I love using clay bars. There are lots of links explaining how to do it. Biggest thing to remember is don't be cheap -- if the clay is dirty, switch it. Take your time and make sure you give yourself (and your car) plenty of uninterrupted time to do a proper job, including a wax job afterwards. You probably have issues in Arizona that I don't have in Michigan...like heat and sunshine...so ask a local to help you with those issues!
Old Oct 31, 2014 | 05:29 AM
davidg5700's Avatar
davidg5700
I tried the Simonize clay bar that was locally available at the parts store. While it does a good job, I find it to be excessively sticky and hard to kneed out.
A trick I developed using it is to create a lip on the clay when I flatten it out in my palm. I grasp this lip between fingers so that if the clay catches for some reason, the clay will stay in my hand rather than tumble to the ground while my reactions catch up to what just happened.
As you've probably read, if the clay hits the surface your car is parked on, toss it.
Old Oct 31, 2014 | 09:56 AM
BRGPA's Avatar
BRGPA
I always clay before waxing. I like the stuff sold here: http://www.griotsgarage.com/
but there are many other companies that sell it.
Old Oct 31, 2014 | 12:39 PM
angrymini's Avatar
angrymini
i appreciate the feedback. before my mini i had a dodge pos for 11 years that i didnt really care to clean much, but i want to preserve the new car look as long as possible.
Old Oct 31, 2014 | 01:46 PM
Fly'n Brick's Avatar
Fly'n Brick
The Griot's clay bar is included in a kit that also has their quick detailer you spray on to keep the clay lubricated. having the clay 'stick' is often a result on not keeping it lubed.
Here is a good demonstration on using clay bar:
Can't say it enough: If you drop the clay, pitch it, it's done.
Old Nov 2, 2014 | 10:03 AM
TVPostSound's Avatar
TVPostSound
Easiest way:
Wash your car with extra soap in the bucket.
Wash a section, leave the soapy water on the car, proceed with a clay bar on that section.
Then rinse.
You have a clean, and claybar'd car when done.
Don't forget to wx, as you no longer have protection.
Old Nov 2, 2014 | 10:18 AM
bjcarter2's Avatar
bjcarter2
If you're an Amazon fan, I have had a great degree of success with the Meguiar's clay bars.
Aggressive clay bar
Amazon.com: Meguiar's C-2100 Professional Detailing Clay, Aggressive: Automotive Amazon.com: Meguiar's C-2100 Professional Detailing Clay, Aggressive: Automotive
Mild clay bar
Amazon.com: Meguiar's C-2000 Professional Detailing Clay, Mild: Automotive Amazon.com: Meguiar's C-2000 Professional Detailing Clay, Mild: Automotive
Clay bar lube and detailing spray - I use this for touching up nearly the entire car in between washes. Mix 50/50 with water to use as a clay bar lube.
Amazon.com: Meguiar's D15501 Last Touch Spray Detailer - 1 Gallon: Automotive Amazon.com: Meguiar's D15501 Last Touch Spray Detailer - 1 Gallon: Automotive
Old Nov 2, 2014 | 11:18 AM
danjreed's Avatar
danjreed
Aggressive clay bar
Mild clay bar
I second this list. Very good success over the years. All horizonal surfaces get done every couple of months.. whole car 2x a year (fall and spring). Its amazing to see what gets pulled off of the clear coat.
Old Nov 3, 2014 | 03:12 PM
ra2fanatic's Avatar
ra2fanatic
Use Nanoskin. What would normally take hours to get done on the full car, can take minutes. I told a friend to try it out since he never heard of it and it was BLOWN away by how effective it is. For small hard to get areas, yeah I use clay, but panels, nanoskin all the way.
You will s**t your pants when you run your hand on your paint after you've used their pads.
http://www.nanoskinusa.com/products/...ub-system.html
Old Nov 3, 2014 | 08:35 PM
winL's Avatar
winL
I started off claying my car the first time with a clay bar kit. Having no experience with different clays and such, the Meguiars clay kit had everything i need to get started. From then on, i moved onto polishing before my waxing. Then with experience, know whether to use synthetic or carnauba wax for the effect i want. Don't take too big of a bite the first time, get the kit and you'll be in your way.
Old Nov 3, 2014 | 08:36 PM
winL's Avatar
winL
Btw, it's nearly fool proof with messing up when you follow the instructions kn the box.
Old Nov 11, 2014 | 10:05 PM
flatlander_48's Avatar
flatlander_48
I primarily use Zaino products on my MINI, although I have tried Meguiar's clay. I rate the Zaino clay a bit better.
I wash the car first to get the major stuff off the body. Zaino says to lubricate the surface with a blend of their car wash and water. I mix up a batch and use it with a spray bottle. Usually I clay the whole car. Afterwards I wash the car again to remove the soapy residue. Zaino has a polish for clear coat paint jobs (can't remember the name). It is a 2 part system. If I don't use that I will use their quick detailer.
I don't think the clay removes polish. I don't remember seeing that mentioned in any of the Zaino literature. From what I know, all it's doing is pulling out the grit that is stuck to the surface. The liquid and frequently folding the dirty clay in keeps the imbedded grit from scratching the surface.
YaTuSabe
Aug 23, 2018 11:41 AM
gar56
Nov 15, 2016 06:41 AM
bahman
Feb 14, 2016 10:29 AM
vulkandino
Oct 31, 2015 08:29 PM
mauiguyharry
Oct 8, 2015 06:53 PM
