Well, CRAP, I have a leak.
Just starting finding small drops of motor oil under the car, close to the front, right side.
I know someone will know what's leaking, unless it's common for these cars to leak from various places.
2004 R53 167K
2004 R53 167K
The engine mount is the most common to leak near the right front.
The crank sensor seal is at the front of the car and middle so I wouldn't consider that to leak near the rt front.
I agree with suggestions that it is probably the engine mount (thick black goo) or the crankshaft position sensor seal (normal oil).
Here is diagram of what the engine mount (#3) on passenger side looks like:
Here is diagram of where the crank position sensor (#8) is located:
Clean the engine well and then look for the leak. Many people (including Mini Techs) have changed the oil pan gasket trying to resolve an oil leak when the leak was actually coming from the crank position sensor.
Check the oil filter housing and cooler. Sometimes leaks from the oil cooler attached to the filter housing can appear to be more like oil than coolant by the time it reaches the garage floor.
XsV
24
Sep 30, 2015 03:17 PM
riff42
Sep 22, 2015 03:07 PM
Sep 2, 2015 09:05 AM
Indimanic
Aug 19, 2015 11:08 AM
