R56 Final drive ratio U.S. spec vs. Euro spec
Old Oct 14, 2014 | 08:44 AM
LZRBLUE's Avatar
LZRBLUE
On a recent trip to Europe we rented an Opel Mokka 1.4T 6/spd at nearly 90mph (130kph) this little SUV we rented was only turning 2,500 rpm!
Which got me thinking about how I wish my mcs was a little more fuel efficient.
Does anyone know if the euro spec mcs has a lower final drive ratio?
If so where could I get the ring and pinion set from?
Thank you.
Old Oct 14, 2014 | 09:40 PM
renchjeep's Avatar
renchjeep
Wouldn't it be nice to have a 7th gear? Drop the RPM's to 2,500 or so while cruising at 90 MPH? I hate seeing the rev counter so high at freeway speeds...
With a higher (numerically lower) final drive, our Mini's would lose the "grunt" we all love so much!
Old Oct 15, 2014 | 02:00 AM
Angib's Avatar
Angib
I think you need to readjust your ears. In the 1970s I had a little factory-tuned Fiat (SOHC, 2 valve) that cruised at 5500rpm, red line at 7000. Now that was a bit 'revvy'.
Old Oct 15, 2014 | 03:27 AM
Drivehard's Avatar
Drivehard
I bet you dont remember how the OPEL accelerated while driving. ............... Because it didn't because it couldn't It's hard to have both worlds but I think the minis do a great job. Our 6th gear has a decent overdrive to lower the revs.
Sent from my iPad using NAMotoring
Old Oct 15, 2014 | 04:20 AM
spiney's Avatar
spiney
Was it a diesel? Because of the low end torque of the small turbo diesels and the low rev limit many of them are geared very high.
Old Oct 15, 2014 | 06:43 AM
LZRBLUE's Avatar
LZRBLUE
It wasn't a diesel. It accelerated ok for what it was which is a small SUV. Yeah it didn't take off like a mcs but it was alright.
In traffic you could barely get into 3rd because it would just fall on its face. Once you were around 50kph+ you could use the rest of the gears keeping the rpms low.
Old Oct 15, 2014 | 09:59 AM
Slave to Felines's Avatar
Slave to Felines
I personally would love to see taller 5th and 6th gears. I think 1-4 are pretty close to perfect as they are (for my Justa) and would not like to see a taller final drive, because that would make all six gears taller. But in particular a taller 6th, and therefore a slightly taller 5th to keep the rev drop a little more even, would be a welcome boost to fuel economy without sacrificing my own enjoyment. Because, frankly, if I'm thrashing the car it's going to be in the lower gears anyway.
Old Oct 15, 2014 | 11:26 AM
spiney's Avatar
spiney
I must admit going for 7th now and again on the highway in my S...
Old Oct 15, 2014 | 09:03 PM
renchjeep's Avatar
renchjeep
Been there, done that too, spiney! Not finding 7th, back into 6th I went. The wife looked at me kinda funny. She even LOL'ed at me! Later, on the same trip, I caught her doing the same. We are even now...
Old Oct 16, 2014 | 01:16 AM
Systemlord's Avatar
Systemlord
You would have to downshift into 6th gear going up a mild incline if there were a 7th gear in our Mini's, the high MPG cars (Toyota, Honda etc.) make most of their power/torque at 2200 RPM's in order to maintain a steady 65-80 MPH. I'm amazed that these MCS's get 30+MPG at 75 MPG at 3000 RPMs!
Old Oct 19, 2014 | 04:21 PM
Btwyx's Avatar
Btwyx
Our other car has a very tall top gear, it does 70 at 1700rpm. It doesn't sound happy doing it though, so I usually drop it down a gear to get the revs up to 3k. It uses a lot less gas in the higher gear though, so I'm trying to see if I can get used to the low revs.
Old Oct 19, 2014 | 11:53 PM
Systemlord's Avatar
Systemlord
From my experience the Sport Button helps you maintain a steady speed even on most inclines, I find myself not having to downshift as often and less back and forth adjusting pedal for inclines. The Sport Button also helps out a lot on steep inclines like those in the mountains passes where I like to go, lots of sharp S type turns!
ej
Sep 28, 2015 05:41 AM
flredmini
Aug 12, 2015 06:35 PM
xpunisherx
Aug 10, 2015 10:50 PM
RHcoopers
Aug 6, 2015 07:33 AM
