replaced the window regulator
Old Oct 14, 2014 | 04:54 AM
traildog's Avatar
traildog
I figured out why the seller included the new window regulator when the passenger side window stopped working last night.
I also found the 2 large white cable clamps broken when I removed the door panel.
I know ECS sells a complete hardware kit, but, I only need the clamps.
Are they essential to the operation of the window?
If so, I'll be stopping at the dealership. They will probably charge $25.00/each, but, I need to get the car back on the road.
Old Oct 14, 2014 | 07:13 AM
Webhead68's Avatar
Webhead68
If they are the window clips that hold the top two cables they are kind of important. I forgot to clip mine in and it ruined my window tinting on that window. I looked for the clamps on realoem.com and can't seem to locate them. They are displayed on the Window Regulator but no part number is given. Good luck.
http://realoem.com/bmw/showparts.do?...71&hg=51&fg=10
Old Oct 14, 2014 | 01:38 PM
traildog's Avatar
traildog
I stopped at the dealer and they had a fastener that popped into the hole wher the clips were. It had a loop on the top for a zip tie...worked like a charm.
Now I need to figure out how to stop the whistle. Must be the adjustment at the bottom of the door.
Old Oct 14, 2014 | 08:07 PM
Kahnfucious's Avatar
Kahnfucious
Originally Posted by traildog
I stopped at the dealer and they had a fastener that popped into the hole wher the clips were. It had a loop on the top for a zip tie...worked like a charm. Now I need to figure out how to stop the whistle. Must be the adjustment at the bottom of the door.
Whistling when driving is usually tied to the black pillar in front of the door..not window seals.
Old Oct 15, 2014 | 01:34 AM
traildog's Avatar
traildog
Hmmm. I figured it was the window because it didn't whistle before I messed with it.
Old Oct 15, 2014 | 03:26 AM
Kahnfucious
Could still be...have you done the "calibration" for the window to lower partially when you open the door? Making sure it seals all the way when you shut it? Easy way to check is to see if closing button all the way solves it.
Lastly while I was thinking about it---there is slight adjustment if the window when you touch the regulator.. I brought up the pillar as another idea
Old Oct 15, 2014 | 08:20 AM
traildog's Avatar
traildog
Actually, no, I didn't do the calibration because it seemed to be right on the money when I buttoned it up.
Looks like it matches the driver's side window as well.
Old Oct 15, 2014 | 10:53 AM
xsmini's Avatar
xsmini
It doesn't take much miss alignment to get a whistle. There is some adjustment on the bottom of the regulator. But I've found most of the adjustment to be at the two large white "clamps" (for lack of a better work) holding the window to be much more useful.
good luck, that whistling can get annoying.
Nik
Old Oct 15, 2014 | 02:47 PM
traildog's Avatar
traildog
Whistle gone.....I loosened the clamps and barely moved the window up a smidge.
Thanks for that suggestion fellas.
Old Apr 4, 2015 | 12:24 PM
automan21's Avatar
automan21
Is there a thread for getting to those clips? Im trying the search like a mad man.
Old Apr 5, 2015 | 04:09 AM
traildog's Avatar
traildog
The ones I broke?
If so, mine were in plain sight after I removed the panel.
Old Apr 5, 2015 | 05:51 AM
buzzsaw's Avatar
buzzsaw
http://www.pelicanparts.com/techarti...eplacement.htm. and:
https://www.northamericanmotoring.co...tic-clips.html.
Good luck.
Old Apr 6, 2015 | 10:41 AM
Most of the time they come on the new regulator: The two white clips that hols the cables parallel
But here they come in a kit. 51337031087 ~ $14 for the kit ( one kit per front door) also has the cable clip.
http://www.ecstuning.com/Search/SiteSearch/51337031087/
woodstudio
Mar 15, 2020 08:28 AM
Dec 23, 2015 10:36 AM
PSIChocolate
Aug 13, 2015 12:46 PM
Cal45fan
Aug 11, 2015 03:50 PM
