Alternator/Battery charging question
Old Oct 6, 2014 | 10:49 AM
jsquaredkim's Avatar
jsquaredkim
Hey NAM,
So yesterday my car wouldn't start and had AAA give me a jump. He tested the battery and said/showed me that the battery was fine just needed a charge but my alternator wasn't charging as it was showing 12.8V The A/C works, power steering works and my S/C pulls just as it did before. I drove the car under heavy load for about 15-20 minutes. As I was driving, my battery gauge would dip from 8V-13V.
This morning, car wouldn't start. So I just took the metro to work. Can the alternator die within a couple days? Any advice? Before this incident nothing changed except for the addition of my pulley but that was a couple weeks back. Also the speedo does that dance every time I try to turn it over.
Thank you
Old Oct 6, 2014 | 11:09 AM
ZippyNH's Avatar
ZippyNH
Who did the pulley install??
There have been a few folks who fail to install the ground cable right on the passenger side mount, leading to issues with the electrical system....charging issues first, then sometimes a burnt out ecu.
As to the life lifespan of an alternator....
Have a Toyota highlander (same denso core as the gen1 OEM unit, just different case) with almost 240,000 miles on it....but have known folks who go through a "discount" lifetime units every few months on a mini.....
Units don't tend to last as long on a mini...rpms are tough on the bearings and brushes...The highlander crises at 2000 rpms and rarely goes above 3000....my mini cruises at 3200....
But you USUALLY get a RED light with an alternator failure...
Old Oct 6, 2014 | 11:15 AM
jsquaredkim
madness motorworks did the pulley install. If the ground wasn't connected, I don't think the battery would've lasted two weeks without charging but I could be wrong.
Old Oct 6, 2014 | 11:28 AM
ZippyNH's Avatar
ZippyNH
Since they are a pro shop that knows mini's, I'd say they are competent.
My guess....
Your PS pump (very common issue)or maybe another item (lights by accident or mechanical failure) did not turn off...and killed the battery..
I would listen in a quiet location, like a garage, car off...and listen for the PS pump...try to turn the wheel...see if it moves easy, like the pump is running.
Old Oct 6, 2014 | 11:38 AM
jsquaredkim
As I was pulling away from my driveway, I have to go at it at a 60-70 degree angle, and it was fluid so I don't think it's the power steering. Can it be a bad battery? even though the AAA guy said it had no bad cells? Also I only drive about 8 miles a day, total of maybe 20 minutes, and basically none on the weekends.
Old Oct 6, 2014 | 12:14 PM
ZippyNH's Avatar
ZippyNH
One failure mode of the PS pump is IT DOES NOT TURN OFF.....but works fine with the car running...thus killing the battery.
A bad battery will loose power as it sits, a "test" is usually just a load test and a voltage test...no longer term check to see if it self discharges.... Out of car is best to see if a cell is bad to isolite a "phantom" load, like a bad PS pump.
Old Oct 6, 2014 | 12:34 PM
jsquaredkim
oh so turn the key to the on position and see if it turns without too much hesitation? is that what you are referring to?
Old Oct 6, 2014 | 06:51 PM
jsquaredkim
so i just checked if the power steering pump makes any noise with the car off, i don't hear anything and without the engine on, the wheels turn pretty smoothly. i tried turning my headlights on just because and the car blacked out basically. any other advice would be greatly appreciated.
Old Oct 7, 2014 | 11:54 AM
jsquaredkim
found out that the alternator regulator failed. autozone out of all places
Old Oct 7, 2014 | 01:06 PM
JABowders's Avatar
JABowders
Veteran: Army
If you are still having issues with the voltage dropping off and crazy electrical antics when your engine is under heavy load (lights on, A/C blowing, etc.) Have the crank pulley checked (Vibration Damper) see the bottom of page one of this post: https://www.northamericanmotoring.co...y-blk-r53.html
Motor on!
Old Oct 7, 2014 | 01:18 PM
jsquaredkim
after getting a jump today it stayed relatively flat at 13V but I'll be sure to check it out. Thanks! curious though where did motor on! come from?
Old Oct 15, 2014 | 11:03 AM
MINI-Madness's Avatar
MINI-Madness
Hi, Madness here, sorry to hear you are having problems. You are correct if we had messed up the wiring you wouldn't have had any charge in your batter. I am glad you were able to find out the problem, please feel free to call us if you have any further problems.
Old Oct 16, 2014 | 12:44 PM
jsquaredkim
will be swinging by soon to pick up the rear sway bar and oil catch can and some of my stock stuff
Old Oct 28, 2014 | 04:00 AM
-=gRaY rAvEn=-'s Avatar
-=gRaY rAvEn=-
Moderator
12317512174 voltage regulator $147.72 #2
Colt45Magnus
Aug 27, 2024 05:03 AM
elightbo
Tires, Wheels, & Brakes
Sep 2, 2015 08:17 AM
elightbo
Aug 17, 2015 01:50 PM
Getrieben
Aug 15, 2015 09:09 PM
Ambient Thermal Management
Aug 7, 2015 12:27 PM
