Passenger Window Not Working
Old Oct 1, 2014 | 03:12 PM
lazabby's Avatar
lazabby
The passenger window suddenly stopped working. All I get is a single "click" when I press the muttong but no action. The window doesn't even slight go down when the door is open. Is the window motor shot beyond compare? If not, how can this be fixed?
Old Oct 1, 2014 | 06:08 PM
WhoHasGotTheBlueS's Avatar
WhoHasGotTheBlueS
Hi. There are lots of threads about this problem for 1st gen. Probably it is your motor but could also be your regulator. I just replaced both on my driver side.
There are various DIYs out there and Pelicanparts.com has a reasonably good how to guide.
People will tell you that you can use the "Fonzie" method to make it work temporarily. Simultaneously hit the door above the speaker and press the toggle switch. Sometimes this will get it going. People hit it with the heel of their hand or a rubber mallet. My recommendation is once you get it working, don't delay in replacing the motor because it is easier to remove the glass if you can lower the window a bit. Mine wouldn't budge so I had to unscrew the motor from the motor housing in order to get the window to move without cutting the regulator cable.
The consensus seems to be that you should use a Genuine MINI regulator if you have to replace that.
If you decide to do this, feel free to PM me.
Last edited by WhoHasGotTheBlueS; Oct 1, 2014 at 06:09 PM. Reason: wanted to note fonzie method is temp. fix.
Old Oct 1, 2014 | 07:34 PM
gknorr's Avatar
gknorr
Yup, hitting the door above the bottom speaker while simultaneously pushing the switch repeatedly has been working for me for years - I would say at least 5 years. In fact, based on my experience, if it doesn't work, you're not hitting hard enough or enough times.
With that said, if you don't want to get in the habit of punching the door, there is a way to "recondition" the motor that's not too bad described over on the MINI2 forum. The motor seems to get dirty over time causing incomplete contact with the brushes. Removing, disassembling, and cleaning solves the problem - no need to replace the motor. Maybe someday I'll try it when I'm tired of punching the door
Old Oct 2, 2014 | 04:54 AM
WhoHasGotTheBlueS
Having just taken my motor apart, I am skeptical of the theory that it is caused by a "dirty motor". I had seen that post on MINI2 and thought that cleaning the commutator would be a solution until I took mine apart. When I got my motor opened, the commutator was a tiny bit dirty but not significantly. The brushes were barely worn. But the armature teeth were very worn, and I think this is a reason why the window stops working. I think banging on the door lets it get over the steps between worn areas and unworn, until the steps get so deep you can't get bang the door hard enough to jump over them.
I have more to my analysis but I'll save it for another time.
Old Oct 4, 2014 | 03:47 PM
lazabby's Avatar
lazabby
Can someone send me the links on that discussion and how to remove and repair?
My car is the 2004 Mini if that makes any difference on repairs.
Old Oct 4, 2014 | 03:55 PM
lazabby's Avatar
lazabby
I went out and banged on it. Sure enough it worked!
Old Oct 4, 2014 | 05:32 PM
gknorr's Avatar
gknorr
Originally Posted by WhoHasGotTheBlueS
Having just taken my motor apart, I a skeptical of the theory that it is caused by a "dirty motor". I had seen that post on MINI2 and thought that cleaning the commutator would be a solution until I took mine apart. When I got my motor opened, the commutator was a tiny bit dirty but not significantly. The brushes were barely worn. But the armature teeth were very worn, and I think this is a reason why the window stops working. I think banging on the door lets it get over the steps between worn areas and unworn, until the steps get so deep you can't get bang the door hard enough to jump over them.
Very interesting. Having never taken mine apart, I just accepted what that other thread covered. Always great to have a second opinion. Do you have any pics of the worn teeth?
Old Oct 4, 2014 | 09:38 PM
WhoHasGotTheBlueS
I do! Check out my post 3-4 posts up... there's a photo there that shows the worn armature teeth.
Lazabby, you can find a DIY at Pelican Parts, here:
http://www.pelicanparts.com/techarti...eplacement.htm
Old Oct 5, 2014 | 11:37 AM
gknorr's Avatar
gknorr
Ah, didn't realize it. The silver parts, some of which are colored green?
Old Oct 5, 2014 | 01:42 PM
WhoHasGotTheBlueS
Yes, exactly. Just below the green bit, you'll see a ridge or step in the armature tooth. There were several such features on mine.
Old Oct 5, 2014 | 02:23 PM
gknorr's Avatar
gknorr
Gotcha. That certainly makes sense.
Has anyone tried any aftermarket replacements since the OEM seems to be flawed? I ordered some ACI motors for mine - will finally be replacing them soon.
Will be interesting to see how the wear in my old motors compares to that picture.
Old Oct 5, 2014 | 02:31 PM
WhoHasGotTheBlueS
Definitely post photos of your old motor(s) when you replace them.
My take on the reason for the wear is that the bearing at the end of the shaft is too loose in its seat. When the motor's worm gear engages the other gear, the seat play allows the motor to move off axis & wobble, leading to rubbing between the armature teeth and the magnets. If I am correct, for another brand to perform better the OEM they would have to have a tighter fit between the shaft bearing and seat.
Dec 23, 2015 10:36 AM
minicoclub
Aug 25, 2015 09:07 AM
clintmeister
Aug 12, 2015 11:11 AM
DWooderson
Aug 10, 2015 09:12 AM
