Interior/Exterior Boost/Coolant gauges for mickey mouse config.
Would like to add a boost and coolant gauges to my R53. I have the nav system, so I have a speedo and tach are behind the steering wheel.
The options I've seen on Mini Mania show the gauges partially blocking the air vents. Would like to hear from anyone with this type of configuration on how much blockage occurs and whether the gauges can pivot up to provide more air flow.
I realize it is not ideal placement, but I have heard there was a cluster that could be placed below the toggle switches (and above the cup holders), but I haven't found any info on this.
I don't want to go with an OBDII solution like Scangauge because I have an ODBII device to record AX and track day data. If I decide not to go with analog gauges, I may just use the OBDII with my iPhone and DashCommand or equivalent.
Deven
Deven
You Talking About This Gauges?
This Ones Came N' My R53 04
All Ready.
Temperature Oil and Volts
Also I Install The Boost Gauge.
At The Side Of The Tachometer.
N' They Block At Little The Air
But Not That Much......
Attachment 99977
Maybe N' The Other Side Block More The Air Vent But I'm No sure.
I Want To Install The Temperature Water
Or The Pressure Oil.
But I See Later What Came First......
Hope This Help You At Little Broh!
All Ready.
Attachment 99977
Gauges
Those are waaaay cool man! I may just have to put those on my Mayfair! I am running a Torque set on an old android phone now using a bt OBDII adapter from Amazon...($15)
All Ready.
Attachment 99977
All Ready.
Attachment 99977
Yes, that is the type of console mount I was trying to describe. Anyone know if they are still available?
Interior/Exterior Getting Through the Firewall
papawhiskey
Sep 30, 2015 02:50 PM
