R50/53 No Lower steering racks in USA?
Old Sep 25, 2014 | 06:30 PM
eric-d's Avatar
eric-d
How is this possible?
This part is on back order for more than 3 months...WTF?
Part #: 32-30-6-763-722-M26
Attached Thumbnails No Lower steering racks in USA?-r53-steering-column-lg.jpg
Old Sep 25, 2014 | 06:34 PM
RDY4TKF's Avatar
RDY4TKF
Try Detroit tuned.....they have it available for right hand drive cars but can be modified for our cars.
Old Sep 25, 2014 | 06:36 PM
ZippyNH's Avatar
ZippyNH
+1
Mini has stated that the right hand drive will be the only ones made....so you must modify them to install them in right hand drive cars....there is a SB on how to do this.
Old Sep 25, 2014 | 06:37 PM
RDY4TKF's Avatar
RDY4TKF
http://www.detroittuned.com/mini-coo...ng-repair-kit/
Old Sep 25, 2014 | 06:39 PM
eric-d's Avatar
eric-d
Interesting. Thanks for the info!
Old Sep 25, 2014 | 06:52 PM
Nicefeet's Avatar
Nicefeet
It's telling when they've already brought in engineers to craft a service note about using up right hand drive spindles. I have a strange feeling this is part going to be NLA.
Back order pfft MINI just wants us all to buy new MINI's
Old Sep 26, 2014 | 02:03 PM
We have it here, 32306763727 is the RHD version that can be used in LHD ( US ) MINIs with a couple quick steps.
Repair Kit Lower Section Of Steering Spindle Conversion part
http://www.ecstuning.com/Search/SiteSearch/32306763727/
Here is the hardware:
http://www.ecstuning.com/Search/SiteSearch/32306781749/ lower bolt
http://www.ecstuning.com/Search/SiteSearch/32206782616/ lower nut
32306763722 was on BO and then came available , but quickly sold out and was for down vehicles only. We don't have eta on the new ~722 , but we do have the ~727 part above. So you can get your MINI fixed and the steering column working right again.
Thanks .
Old Oct 28, 2014 | 04:31 AM
-=gRaY rAvEn=-'s Avatar
-=gRaY rAvEn=-
Moderator
*** when the lower steering assemblies are swapped out, the lower bolt and nylock nut needs to be changed too ! The new lower steering shafts are set up for right hand drive, so you have to remove steering wheel and re-center it along with having an alignment done.....( it's off by about 30 degrees ) There is a BMW bulletin on it.
Old Oct 30, 2014 | 01:14 PM
02r50ryder's Avatar
02r50ryder
I waited from April until mid September then Mini of Ann Arbor Michigan replaced mine.
It works great now so they are available.
02R50Ryder
theblackfalcon
Oct 11, 2015 09:49 AM
nomar116
Aug 14, 2015 04:54 PM
minipopkart
Aug 13, 2015 05:22 AM
Aug 12, 2015 01:24 PM
