R53 front end popping after LCA bushing change
Old Sep 25, 2014 | 06:45 AM
jamfred774's Avatar
jamfred774
Last weekend I dropped the sub frame on my Cooper S to change out the lower control arm bushings for the prepressed powerflex bushings from Way. The install took a while as I had never done a sub frame drop before and it seemed to go together great.
Now when I have the steering wheel turned and drop off the driveway from the house to the street I get a loud pop sound. It is coming from the drivers side. I am assuming ball joints now but I am not sure. I have 88k on the clock and and I don't think they have been changed out before.
Thoughts?
Old Sep 25, 2014 | 02:49 PM
nkfry's Avatar
nkfry
Too broad of a question, but my answer is going to be, make sure all the fasteners you loosened are retorqued to manufacture spec.
Phone:586-792-6464
Info@DetroitTuned.com
Nick@DetroitTuned.com
Old Sep 25, 2014 | 03:06 PM
Capt_bj's Avatar
Capt_bj
old programmer adage . .
when you are sure everything is right
and the program does not work
something you are sure of
is wrong
if it did not POP b4 ... I'd have a good guess of where the POP is comin' from . .
I ran a GEN1 for over 100,000 ... had to replace the control arm bushings but ball joints? naaaaa
Old Sep 26, 2014 | 06:01 AM
jamfred774's Avatar
jamfred774
I double checked the torque values on everything and they are good. The control arm bushings were shot as I could move the front wheels forward and back an inch each direction. The arms came right out with the rubber in pieces which is why they were replaced.
I am pretty sure this car was beat on before I got it as there is a bunch of stuff that needs fixed.
silence2-38554
Nov 12, 2015 09:39 AM
azntaiji
Aug 13, 2015 03:24 PM
minipopkart
Aug 13, 2015 05:22 AM
minipopkart
Aug 9, 2015 12:13 PM
FatherG
11
Aug 7, 2015 07:49 PM
